Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 03-30-2002, 03:21 PM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
HELP!!! I think I blew up my grocery cart!
OK, here's what's up. I'm cruising along up this hill to go snowboarding this morning, and I am going about 30 in 1st, passing an annoying beetle, when I lose power and my ZC sputters. So I coast off the road and open the hood, and I can't see anything wrong. I try to restart it, and it will run for just a second and then stop. Then, I pull out the #1 spark plug and there is OIL all over it. What could this mean? I took off the valve cover, and there is no problem there. Before I start tearing things apart, does anyone have any avice?
to my ZC!
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
Old 03-30-2002, 06:52 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Oil on the top of the plug? or on the electrode?
If its on the top of the plug then its the oil seal in the rockercover. You just need to replace the gasket and seals in the cover, and give the plugs and holes a really good clean to get all the oil out.
If its on the elcetrode, then yes you have a big problem.
Most likely blown piston ring, or even a cracked (highly unlikely) piston.
You need to do a compresion test to make sure though.
Old 04-01-2002, 10:13 AM
4GZChatch's Avatar
Shopping cart
So if I was to change my valve cover gasket, do I use an Integra from 88-89? Or do I need a prelude set? Thanks for your help.
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Progress sway
SAFC
etc. etc.
