Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-28-2005, 06:24 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
compression check.
my boost gauge ever sence i got it has been showing me idleing at 10 vac and 15 while crusing. i finally got around to doing a compression check on my 96 gsx. looks like bad news. this is what it was through all 4 cylinders
im not really sure what this means. the car still runs preatty well, no misfiring, no stalling, smooth acceleration but its defnitly not fast!!. what needs to be done to get the compression back to 180 range?
DSM geek
Old 03-28-2005, 09:08 PM
pr0's Avatar
pr0 pr0 is offline
Re: compression check.
133 psi is the service limit, I guess you're getting there. Time for new rings maybe?
Pete (RS_T atx)
Old 03-28-2005, 09:16 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
either rebuild it or drop in a six bolt. you might want to do a leakdown test and figure out where its leaking from. this will tell you if its the rings, the HG, or a valve not closing completly.
you can also do a dry and wet compression test. do it dry first then pour a shot of oil down each spark plug hole and see how much the reading goes up. if it goes up a lot then its probably your rings
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 03-28-2005, 10:20 PM
i'll do a wet compression check in the next couple days to see if its my rings! thanks.
DSM geek
Old 03-31-2005, 04:52 PM
fatfuck fatfuck is offline
Banned
ahh
I would'nt suggest pouring oil in there, a tablespoon or two should do. are you holding your throttle open while you check compression? you need to use a screwdriver or something to hold it open while you test. Dude is right, if you do the wet test and compression goes up. time for new rings.
Old 03-31-2005, 04:54 PM
Banned
actually
hey your psi reading is in blue. seems to me your registering 140 psi in all cylinders which is good. dont fuck with it. You might be reading the wrong dial.
Old 03-31-2005, 05:43 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Yes he is getting 140 to each cylinder but 140 = Good? WTF are you smoking? That is far from "Good"!
Old 04-24-2005, 12:57 PM
well. i finanly got around to doing a wet compression check on the old beast. i did this morning after letting it sit overnight. im not sure if that makes any diffrence. but here is what i got
New Wet: 162-172-160-164
Month ago dry: 140-141-141-140
so. not sure what to do next. i was expecting the compression to be higher then 160+ when i did the wet check. if it was solely the rings would the compression be higer? any suggestions?
DSM geek
Old 04-25-2005, 11:41 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
those numbers basically say your rings are getting pretty wore out. it's either time to give that beast a re-build or just drop a damn 6-bolt in it and really haul some ass. a wet compression test won't seal them up like brand new, but it will give them a little better seal, that's why the numbers go up...but not by like 40 points.
95 Talon TSI AWD
97 Eclipse GST
Old 04-26-2005, 10:05 AM
yeah, i have a 6bolt in my garage i need to get working on. i doubt it will be ready to drop in by this winter. who knows.
DSM geek
Old 04-27-2005, 11:23 AM
currious. how far can i take the motar the way it is? would i beable to run mid/low 13's with such low compression??
DSM geek
Old 04-30-2005, 06:22 PM
i wouldn't try it. just re-build it before you really fuck something up.
95 Talon TSI AWD
97 Eclipse GST
