Old 03-28-2005, 06:02 PM
muzzy1maniac's Avatar
muzzy1maniac muzzy1maniac is offline
wheel bearing
Is there an acid test to check wheel bearings? I'm getting a lot of road hum comming from what seems to be one of the front wheels. Is there a way to tell if it's the bearing? Also, if it is a bearing, do I have to do anything special with the locking hubs?
Old 03-28-2005, 06:18 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: wheel bearing
Acid test?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-28-2005, 06:34 PM
ricksza's Avatar
ricksza ricksza is offline
Re: wheel bearing
Your're blazer doesn't have locking hubs, the hubs are always locked into the axle shafts. The axle shaft itself engages and disengages.
An easy way to tell if a hub bearing is causing a noise is to listen on turns. Make a few "S" turns. The noise will change with left and right hand turns.
Old 03-29-2005, 05:23 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: wheel bearing
More than likely it's one of your wheel bearings with that hum... The acid test is to jack up the front and move the weel, anything more than a mm of movement in the hub while rocking the wheel (look at the back of the hub while doing this) you will need to replace.
Old 03-29-2005, 08:14 AM
53bruce 53bruce is offline
Just replaced a bad drivers side wheel bearing on Transport. It looks simular to my Blazer. The sound was a low growling that increases in ptich as you go faster. it for sure came out of the wheel in question.
More than likely, you will need the whole assembly if you have 4 wheel. the assembly will be the spinner and bearing assembly all in one and it will set you back about $90.
After replacement, the growling is gone and the car is happy once again!
Old 03-29-2005, 09:13 AM
Re: Re: wheel bearing
The hum disappears on S turns and does get louder as speed increases. I have the repair manual and it looks pretty straight forward. Anything special or tricky I should watch for? The funny thing is I'm going to be doing this on my kids Grand Am later this week.
Settle something for my GF - when refering to left and right in a vehicle is it from sitting in the vehicle or standing facing the vehicle? I know the answer but my GF refuses to believe it maybe your answer while get through to her!
Old 03-29-2005, 09:16 AM
Originally Posted by BlazerLT
Acid test?
Yes - Acid Test. Meaning an end all positive proof test.
Old 03-29-2005, 10:51 AM
blazee's Avatar
blazee blazee is offline
Problem?
Re: Re: Re: wheel bearing
Oh the girlfriend excuse...........if you wanna know just ask ........ Just kidding.
Left and right is determined by sitting in the vehicle. Driver's side is left and passenger's side is right.
The tell-tale sign of a fading wheel bearing is a growl accompanied by a vibration. The sound and vibration will increase with vehicle speed. While turning in one direction the symptoms will get worse and while turning the other they will seem to fade away (unless both sides are bad). Usually the right front is the first to go.
You can search this forum.... a lot of walkthroughs have been posted.
Old 03-29-2005, 11:02 AM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: wheel bearing
how are your tie rods?
Old 03-29-2005, 11:25 AM
I dunno -What do I look for?
Nice Blazee - Yes it is a real argument. My GF complains of something on the right front - like with the tire- and I go out looking and guess what - I don't usually find anything!
Thanks guys!
Old 03-29-2005, 11:27 AM
Re: wheel bearing
pull the front end off the ground, if your wheel is locked and you can move the tire left and right, tie rod ends are bad
Old 03-29-2005, 12:29 PM
BlazerLT's Avatar
AF -Advisor
Re: wheel bearing
up and down is to check the bearings.
left to right play is the steering assembly.
Old 03-30-2005, 08:03 AM
Re: wheel bearing
Ok, I went for a ride... when I turn right the sound stays and when I turn left the sound disapears. I should have some daylight left afterwork today to lift it and check for play.
Old 03-30-2005, 03:29 PM
BlazerLT's Avatar
AF -Advisor
Re: wheel bearing
yip, if you turn left and unload the driver's side wheel and the noise goes away, you have found a bad bearing.
Old 03-30-2005, 04:22 PM
Re: wheel bearing
I got home and lifted the truck. The right side clunked when I rocked it top to bottom. Just S & G's I lifted the left and it was rock solid. The next question is what's better - GM or aftermarket??? I can get the GM part for $185 shipped and the aftermarket for around $100.
