Old 03-28-2005, 05:04 PM
shawnwilliams's Avatar
shawnwilliams shawnwilliams is offline
Why Cant I Do this
I have 2 300rms subs (4ohm)
I hook 1 amp that is 300rms (Bridged 4ohm) to 1 sub and it works fine.
Then b/c i have 1 pre-out on my deck i use the out-put on the amp to hook up my other amp. The other amp is 200rms (Bridged 4ohm). When i play it works great for 2 minutes then my entire systems sound gets cut in half. (half the sound at the same volume). Why cant i hook up 2 amp to my 1 output deck, and i'm not sure waht to do.
Should I: (the best cheapest way for my system to work properly)
1. Just get an amp at 600rms at 2ohms and hook up both subs to it.
2. Split the rca cable with 2 y's to create 2 rca cables to goto the amps.
3. Get a newer Deck.
4. The amps aren't getting enough power. (need bigger gauge wires)
5. Other way please tell
TY
Old 03-28-2005, 05:22 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Why Cant I Do this
when it gets half as loud, are either of the amps off or in protection?
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 03-28-2005, 05:48 PM
Theres still bass from the subs so they'd have to be on.
Old 03-28-2005, 06:24 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Well, can't really say without looking at it. Personally, I'd either take one amp and run it 4ohm stereo or get a better amp that can go 2ohm mono.
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
Old 03-28-2005, 06:52 PM
The amps work fine by themselves to 1 or 2 subs, and there both 1 ohm stable. but when i hook both amps up they dont work.
incase your confused i have 2 subs and 2 different amps, i hook 1 amp to 1 sub and the other amp to the other sub, but due to 1 output on my DecK i have to run the rca cables input on one amp and output that and input the other. That's when it doesn't work. (you know you have an input and an output on your amp).
