mixing antifreeze
I recently bought a 98 tacoma and it has orange antifreeze in it now.It's a little bit low, can I put the green kind in to fill it up?I have the green kind already and would rather use that up before buying some more.
Re: mixing antifreeze
It's not a good idea to mix coolants because they have different corrosion inhibitors and may not mix well. Texaco to name one makes a red coolant that meets Toyota requirements.
Clifton |
isnt the factory coolant color from toyota red? is it okay to mix dex-cool (orange) to the coolant resevoir? also, prestone (i think it is) says its okay to mix with all colors of anti-freeze? is this okay? i probably wouldnt want to trust mixing the colors unless i have to.....
dont mix unless it tells you you can. if the two arent supposed to mix i could turn th coolent into a jell. that would be bad. so its a good idea to drain it, flush it, and replace it.
Most coolants can be intermix regardless of the color. I mix the green and orange ones all the time. Coolants are nothing but rust inhibitors with anti-freezing qualities. Note: There two chemically different coolants however which should not be mixed. One is the ethrlyne-glycol which is the most popular, the other I don't know.
i just bought the oem antifreeze from the dealership. guess how much it cost for a gallon?!? 24.58!!! but i guess its worth it knowing u have the right stuff in there.....
