Go Back   Automotive Forums Car Chat > Chrysler > Lebaron
Old 03-28-2005, 02:29 PM
sosturbo sosturbo is offline
85 lebaron - carb setting after choke repair
85 lebaron - mitsu motor - choke linkage was broken and repaired. still not running well. Looking for info on adjusting carb or troubleshooting problem - is there as a way to pull computer codes?
Old 03-28-2005, 11:13 PM
cbeck cbeck is offline
Re: 85 lebaron - carb setting after choke repair
I've been told you can go to autozone and they will read the codes for you...
I'm not a mechanic, I'm the guy people bring their car too when they don't run. I usually scratch my head and tap on stuff, then call the dealer to see if they can help me find the carburetor.
Old 04-03-2005, 07:14 PM
[email protected] Chriznat20@msn.com is offline
Oh geez. If you go to Autozone with the old pre-OBD1 system to get your codes read, they are prolly going to drop to their knees laughing.
Use the "key dance" method. Directions here: http://www.allpar.com/fix/codes.html
Good Luck!
2002 Envoy SLT
106,500 miles, AutoRide, 4x4, Navigation
2005 Saturn L300
V6, Chrome rims, Moonroof
44,000 miles
Old 11-15-2005, 11:46 AM
PlanetDude PlanetDude is offline
If it`s carb, there are no computer codes. Those chokes can be a bit of a trick to set.... I fumbled through it once, with some luck..... that`s the coolant fed choke? I`d suggest seeing if anyone around is famalira with those carbs... I became very lucky, a good friend of mine is a mechanic who knows those carbs... they are tricky. Carbs in general nowadays, it`s hard to find someone who knows.
the key on-off method won`t work, there`s nothing there.
Ryan
