Old 03-28-2005, 01:47 PM
murphymotorsport murphymotorsport is offline
Failed
I took my car to emissions and it failed its hc test at idle any ideas what might correct the problem? BTW i have a 1988 HF rex
Old 03-28-2005, 01:55 PM
prude prude is offline
Banned
Re: Failed
check your ignition system.. (ignition misfire causes high HC gas)
Old 03-28-2005, 02:04 PM
dfarres's Avatar
dfarres dfarres is offline
Send a message via Yahoo to dfarres
Re: Failed
my accord did the same thing, it passed everything but HC idle. Your car is not burning enough fuel at idle. I replaced my air filter, plugs, cap, rotor and added RXP to my fuel. Drove it to work (50 miles) and it passed with eaze. The numbers were half.
1993 Civic Coupe EX
1997 Chevy Suburban LT
“It's all fun and games - Until someone loses an eye"
Old 03-28-2005, 02:12 PM
Re: Failed
ok....i'll change plugs and i just got a CAI should i put that on before test 2?
Old 03-28-2005, 02:34 PM
--- --- is offline
Re: Re: Failed
You can, but it won't affect whether you pass or not seeing as the only reason you failed was your idle.
I drive a slow car.
Old 03-28-2005, 03:17 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: Failed
I agree, a tune up should solve your problems
Old 03-28-2005, 03:43 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Yup, like they said, HC's are unburnt fuel. either your not getting proper spark or your running rich.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 03-28-2005, 03:48 PM
Re: Failed
well i put premium in the tank yesterday and this car hasnt been driven / taken car of in like 2 years i put new plugs CAI changed oil and oil filter and put in some fuel injection cleaner....how long u think i should drive it for to get the premium and injection cleaner circulated? What else would u do to make it pass?
Old 03-28-2005, 03:54 PM
Kind of a Big Deal
Re: Failed
id do the full tank just to be sure. did u change the plug wires? what about cap and rotor? those should be changed too.
Old 03-28-2005, 05:45 PM
Re: Failed
Im not new but cap are u talking about distributer cap and what u mean by rotors?
Old 03-28-2005, 05:52 PM
Kind of a Big Deal
Re: Failed
dizzy cap and rotor (rotor is the thing that spins under the cap)
Old 03-28-2005, 05:58 PM
Gohan Ryu Gohan Ryu is offline
Re: Failed
Go for a long high speed run (about 10 mins) then have the guy do the smog check while the engine is EXTREMELY hot. I failed my first smog check and doing that made me pass the second time. Since I knew the smog check guy he told me to park and rev the engine between 3-4000 rpm for about 5 minutes. That heats up everything and makes emissions a little cleaner. He said it's illegal for him to let me do that, and if a state inspector caught me doing that they wouldn't let me test...but it worked!
Old 03-29-2005, 03:51 PM
Hilikus Funkin's Avatar
Hilikus Funkin Hilikus Funkin is offline
Send a message via AIM to Hilikus Funkin
Re: Failed
hmmm we dont have emissions here. HAHAHAHAHA
1991 Honda Civic DX Sedan
Old 03-29-2005, 04:28 PM
DirtyD777's Avatar
DirtyD777 DirtyD777 is offline
Send a message via MSN to DirtyD777
haha..I was just thinking the same thing. So glad we don't have that emmissions crap in MT..then again we are some odd couple thousand feet above sea level I think..that sucks =(
Old 03-29-2005, 04:42 PM
pauls81sc pauls81sc is offline
Re: Re: Failed
Someone once told me NOT to run premium fuel when doing emission tests. He never gave me the scientific explanation for why, but I do know that running higher octane in your HF is not helping.
Octane ratings determine how much you can compress the fuel mixture before it combusts on its own. Higher performance engines need it since they run higher compression ratios.
1989 CRX Si (commuter)
1981 Porsche 911 SC (weekend TERROR!!!)
