Old 03-28-2005, 12:50 PM
Colepack Colepack is offline
Post 1996 3500HD PCM Problem
I have a 1996 Chevy 3500HD that has problems as follows. ABS light on, Check engine light off, No comunication with scanner, No AC compressor control from computer, and a big headache......Any help would be great...Colepack
Old 03-28-2005, 02:56 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 1996 3500HD PCM Problem
Check all the fuses to it. I saw a Chrysler with no spedometer and wouldn't shift out of first, no communication with scanner. Turned out to be just a bad fuse. Of course, you'll want to find the reason the fuse blew, if it turns out that is the problem.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 03-28-2005, 04:34 PM
Re: Re: 1996 3500HD PCM Problem
Fuses good, went through the trouble trees and they all point to a bad ABS modulator valve assy. $500.00 Anyone ran into a simular problem?
Old 03-28-2005, 11:19 PM
mphmilkman mphmilkman is offline
Be carefull before you buy a new abs module. I had the same problem with a 97 wile I was working for GMC. The truck was a 3500hd used for Phone utility truck. The Tech2 would communicate with the ABS. I replaced all kinds of parts after GMs techline was really unable to help. A new module did not help. Checked every wire and terminal. I ended up quitting the GMC job over things like this. The reps don't always resolve the problem and the service manager is looking at you. Anyway, soapbox here.
