Go Back   Automotive Forums Car Chat > Ford > Contour
Old 03-28-2005, 12:30 PM
JimR's Avatar
JimR JimR is offline
Buying SVT
ok i have found a 1998 SVT its only $2,500, but it has a number of problems.
1. bad 1st and 2nd gear 3rd and 4th ok but could be better.
2. some eletrical probs
3. some body damage
4. hesitates when i get on the gas.
ect.
should i buy it or should i let it go.
i dont have tons of $ to spend on it (after i buy it) less then $2k
Old 03-28-2005, 01:14 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
I wouldnt. Tranny work alone would probably run you about $700-1000+ assuming you could pull the transmission on your own. The engine does need to dropped for the trans to be removed. Not sure what your electrical problems entail, but all new main wiring harnesses under the rood would run you about $1300 + labor. Hesitation is probably due to a fuel filter. Too many headaches imho.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 03-28-2005, 02:36 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: Buying SVT
how many miles are on your 96?
you could supercharge the car you have now.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 03-29-2005, 08:53 AM
Jason43's Avatar
Jason43 Jason43 is offline
Re: Buying SVT
Sounds like it would be more work that whats its worth.
Just go to contour.org
1999 Ford Contour SVT
Old 03-29-2005, 10:32 AM
JimR's Avatar
Re: Buying SVT
my 96 has 82,000 miles
guess ill keep looking for another SVT
Old 03-29-2005, 11:17 AM
Jason43's Avatar
Re: Buying SVT
If you were going to buy this one for $2500 and spend another $2000, you could probably find a decent, non-beaten to hell 98 for around $4-5k.
Old 03-29-2005, 12:38 PM
JimR's Avatar
Re: Buying SVT
Found another for $3,500.
took it for a test drive trans is great.
everything works.
BUT the hood dont look to great, the hood looks like someone was dropped on it more then once.
im thinking about buying this one. what do u think?
Old 03-29-2005, 03:00 PM
Re: Re: Buying SVT
everything works.
sounds like it might be a good deal. Might be cheaper to just replace the hood with a carbon fiber one.
theres also carbon fiber hoods available in the oem shape.
"The CEG Nazi"
www.contour.org
Old 03-30-2005, 08:56 AM
JimR's Avatar
Re: Buying SVT
i found out that the svt i was looking at was in a flood. so i guess ill have to stick with the 96 i have.
Old 03-30-2005, 09:27 AM
pre98zetec's Avatar
Re: Buying SVT
why not buy a post-98 SE and get an SVT body kit.. And get a few performance mods?..
Almost as fast.. less the insurance.
-Josh-
Old 03-31-2005, 09:18 AM
JimR's Avatar
Re: Buying SVT
ok i guess that is something to think about.
