Go Back   Automotive Forums Car Chat > Mitsubishi > Mirage
Old 03-28-2005, 10:18 AM
JaCki_StYle JaCki_StYle is offline
cluster
Hi everybody, scuse my english, he is not perfect but i can try to be inderstand.
my question is:
I recently buy a 95 4doors lancer(4g93 powered model) cluster, he fit perfectly in my 95 mirage 4g15 but the tachometer(RPM) didnt work.
someone do this cluster swap?
how do you make the lancer tachometer work, what electric wire do you need to plug behind the cluster...
i dont know if everybody could inderstand what i write but if someone can rewrite my message in good terms, i will be happy
thanks
Old 03-28-2005, 11:19 AM
diymirage diymirage is offline
ok , i.ve never done this swap but heres how you hook up your tach ,
in the enginebay right by the wiper motor there is a little plug coming out of the wiring harnass . mine is yellow but it could also be green or maybe even a different colour . that is your tach feed wire .
hook up a wire to that and figure out where it goes on your cluster (you should just be able to follow the back of it) and it should work
just to be sure though i would first try it with the wire just running outside the car .
good luck man
