Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 03-28-2005, 12:26 AM
luvdrt luvdrt is offline
clutch safty switch ON A 95
Can This Switch Be Cleaned W/contact Cleaner Or Do You Have To Replace It? Or Can You Wire It Direct & Eliminate The Switch? I Think There Is Four Wire Plug Going To It. It's On A 95' 4cyl 5 Speed .....thanks In Advance
Old 03-31-2005, 08:12 AM
cougarman cougarman is offline
I highly suggest you replace it. It is a safety switch and there for a reason.
I worked in a shop once, A tech was working under the hood, he asked another tech to turn the key on to run position, He reached in the window, turned the key just a bit to far, the ranger started up and pinned the tech against a steel work bench, Injured badly. Don't set yourself up to be responsible for a preventable accident !
