Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 03-27-2005, 10:45 PM
Mello_Yellow Mello_Yellow is offline
Unhappy help me
my car is a honda 00' and on acciedently i put diesel in a unleaded car and it was empty and i put about $10 worth of disel gas. I drove it for about 30minutes and it died on me. Would that do alot of damgae and can't be fix?? im so worry...
Old 03-27-2005, 10:52 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: help me
how the fuck do you put diesel into a car ? just drain out the diesel and put in fresh gas and try and start it
Team Lonely Drivers
Old 03-27-2005, 11:01 PM
try draining out already but doesn't work either!
Old 03-28-2005, 12:42 AM
Re: help me
does the fuel pump prime at all ?
Team Lonely Drivers
Old 03-29-2005, 12:37 AM
416 416 is offline
Thats a big problem. You may have drained the tank but the lines and injectors still have all that diesel in them. They also send whatever is in them back to the tanks. SO, you have to clear the lines and possibly flush or replace the injectors. Some say diesel is too big to get past the tiny injector screens but you never know. Take the return line off the fuel rail and cycle the key (get the fuel pump to run) and the shyt will pump itself out. This is dangerous because you will have gas on the ground. Catch it in a bottle if you can. Do this until you see fresh gas come out and then try to start the car. Good luck.
