Old 03-27-2005, 10:40 PM
nalgman's Avatar
nalgman nalgman is offline
Brakes Pulsates during brake application
hello guys.
i need some help from the experts..
my blazer 2wd 4.3Lt Z 1990
has the BRAKES light on in the dash.
when make stop in some where, while i push the pedal to stop the pedal sometimes dont have like pressure.and sometimes when i make a stop the pedal go down normally but a 20% of the times go down doing some pulsates. and other times go normaly and then jump down almost totaly.
this is about the 20 to 30% of the time.
ok, i already replaced this. the master cylinder,rear brakes,the plastics of the pistons of the rear brakes. so a man sayd that this problem would be like the presure valve(combination valve) or the booster.
but i would like to know what do you think.
thanks ..
Nalgman
Old 03-27-2005, 11:10 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Brakes Pulsates during brake application
Sounds like the ABS system needs to be checked out.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-27-2005, 11:20 PM
nalgman's Avatar
okkk this is what i got!
ok.. i have the haynes manual. and have done put the clip to the H and the A terminals (jump) and the book says that the Brakes light will show the codes..
so here is my code..
6 .. the brake light flashes 6 times. so the code is the Speed Sensor.
the manual says this " erratic brake action at low speeds and pedal pressure is a sign of a fault in the speed sensor or speedometer circuit."
ok.. this code causes my BIG problem? ... ok there's too much coincidence..
in this model of blazer where is located this sensor.??
i would thank you help..
Nalgman
Old 03-27-2005, 11:33 PM
BlazerLT's Avatar
AF -Advisor
You need to remove , clean and reinstall the fron speed sensors.
Old 03-31-2005, 12:33 AM
nalgman's Avatar
Re: okkk this is what i got!
ok ok .. one question.
this model of the blazer 90 2WD
has front speed sensors??
The manual says that RWAL (2WD) has the speed sensor in the tranny.
the 4WAL has 4 sensors.in each wheel.
emm. this is my question...
my 2wd blazer has sensors in front??
or just in the tranny?
can be cleaned?
Nalgman
Old 03-31-2005, 05:03 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
The speed sensors being refered to are the abs sensors. They are located in each dust shield on the front. To get them, first you need to remove the hub (clean the teeth on the gear drive for that) and then pull the dust shield. Realize though, the sensor is more likely bad than just dirty, but as suggested, try cleaning it up first. Also make sure that your rotors aren't warped.
Old 03-31-2005, 11:12 AM
BlazerLT's Avatar
AF -Advisor
You can remove the speed sensos without removing the hub.
Old 04-01-2005, 02:36 AM
nalgman's Avatar
Re: Re: Brakes Pulsates during brake application
ok
i'll try to find it tomorrow..
well.. i dont have any idea how looks this sensor. but i'll analize the front wheels.
thank you so much.
Nalgman
Old 04-01-2005, 05:05 AM
rlith's Avatar
look at the dust shield, you will see a wire coming off of it, that's the sensor ring..
Old 04-01-2005, 08:33 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
1990 - its a RWAL system, not 4WAL, no sensors in the front. RWAL's don't have an "anti-lock" light, just the "brake" light comes on for both regular brake system and the RWAL ABS system. To make sure that its the ABS causing the problem, disconnect the RWAL system by unplugging it and taking it for a drive. If you now don't have the pulsing or pedal drop, then you do have a ABS problem. Check your vehicles speed sensor that is located on your outsput shaft, usually they take a shit, and give you problems like that.
Old 04-02-2005, 12:55 AM
nalgman's Avatar
yes! my blazer is a RWAL .
where is located the RWAL system?
the manual don't show where is it.
the speed sensor can cause that??
emm. my dash don't show my speed.somethimes the speedometer runs and 90% not.
maybe this is the problem???
in the test with jumping the pins A & H of the socket to hook up the computer to read the codes.. the Diagnostic for ABS says "speed sensor"="6 blinks"
Thanks
Nalgman
Old 04-02-2005, 03:30 PM
blazes9395's Avatar
Newbie mod
The RWAL system is located beside the brake fluid resevoir, to the right looking from the front of the truck. Its a black box that jets out from the master cylinder. There are two plugs that plug into it, unplug them both, then take it for a drive. IF its now not pulsating, then the mechanical system is working, and the ABS system has the problem. Now, you mentioned that your speedometer is not always working.....thats most likely your problem, the VSS, or speed sensor. The speed sensor(VSS) gives information to the RWAL system for rear wheel lock-up, it also provides information for the spedomoeter-the speed of the car. If your speedometer is not working, the RWAL will also not be getting the right information. Change out the speed sensor, or VSS sensor, also make sure connections to and from the speed sensor are good and not damaged. The truck will also have trouble getting the TCC into lock-up because the ECM uses the same sensor to know when to lock up the TCC too. Either way, take a look at the speed sensor and all its connections, that should correct your problem.
Old 04-03-2005, 01:25 AM
nalgman's Avatar
THANK YOU!!!
the conectors are OK i cheked the cables with my multimeter and it's ok.
i cleaned the sensor and do the same thing. and always has a little transmission oil,but not too much. but i guess that i need to replace it..
in 15 years that kind of things was never changed by the past owner..
Thank you again..
Nalgman
