Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 03-27-2005, 09:04 PM
99saturnspeed 99saturnspeed is offline
HELP I Broke 3 Transmissions!!!
I have a 99 saturn sc2 dohc and broke 3 transmissions. If anyone knows of an after market tranny or has suggestions please conact........
Its a 5 speed. It keeps throwing the diff pin through case into bellhousing.
Old 03-27-2005, 10:50 PM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: HELP I Broke 3 Transmissions!!!
what are you doing that you broke three? auto or manual?
Old 04-01-2005, 12:01 AM
gbic1 gbic1 is offline
Are you spinning one tire constantly or do you have mismatched tire on the front?
1967 cougar 390 FE in progress
1993 F350 Crew Cab 5.8 111K
1983 Coachman 23ft class C 460
1988 Bronco 351 C6
1964 Galaxie 428 4sp project
1995 Mustang 3.8 Auto
1966 Mustang Fast back Project
1994 Tracer Trio 1.9
1968 F250 Camper Special 390
Old 04-05-2005, 01:48 PM
Irish80ca Irish80ca is offline
The same thing happened with me on my 2001 Saturn SC2. The transmission blew up on me and I was told it was from abuse and wheelspin. What a load of bull!!! I've never been stuck in snow or mud but the dealer won't repair under warranty.
Old 08-10-2005, 03:51 PM
drew300 drew300 is offline
Wheel spin: I've been told to not use the small spare on the front end because the difference in size will throw that diff pin.
Old 10-13-2005, 12:38 AM
billyturbonitrosl2 billyturbonitrosl2 is offline
i have also gone through a few 5-speed trannys i bought a phantom grip limited slip diff. block installed it and butt welded the pin on both sides,and that was the end of that problem (any local machine shop can weld your diff good luck.
