Old 03-27-2005, 07:07 PM
blazee's Avatar
blazee blazee is offline
Problem?
Amsoil
While reading the recent Mobil1 thread I noticed a link for Amsoil, I clicked it and have been reading about Amsoil. I think I'm going to switch. Their website shows that it protects better than Mobil1 (I'm sure they're not biased) and have a preferred customer program that you can join and then buy Amsoil cheaper than stadard Mobil1.
Mobil1 VS Amsoil
They sell a "By-pass filter kit" I haven't heard of them before, but they look interesting. https://www.amsoil.com/StoreFront/bf.aspx They are suppose to remove just about everything in the oil, plus they increase the system capacity by one quart. I'd probably go with the BMK-13 so i could just spin the connector on to my remote filter then mount the oil filter and by-bass filter on the frame somwhere.
Bypass Oil Filter Mounting Kits
Engine wear is caused by dirt particles larger than 5 microns. The AMSOIL By-Pass Oil Filter removes particles as small as 1/10 of a micron, virtually eliminating engine wear. AMSOIL By-Pass Oil Filters filter all the oil in a six-quart system in about five minutes at an average engine speed equivalent to 45 mph.
PRODUCT DESCRIPTION
The AMSOIL By-Pass Oil Filter provides the best possible filtration protection against wear, oil degradation, rust and corrosion. Working in conjunction with the engine’s full-flow oil filter, the AMSOIL By-Pass Filter operates by filtering oil on a "partial-flow" basis. It draws approximately ten percent of the oil at any one time and traps the extremely small, wear-causing contaminants and water that full-flow filters can’t remove. The AMSOIL By-Pass Filter typically filters all the oil in the system several times an hour, so the engine continuously receives analytically clean oil.
Do you guys know anything about these? Are they worth it? Also, how good are Amsoil's oil filters? Better than NAPA GOLD?
Old 03-27-2005, 08:29 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Amsoil
Not really worth it unless you are running a fleet.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-28-2005, 02:11 PM
blazee's Avatar
Problem?
Re: Re: Amsoil
I'm not sure what you mean...the membership isn't worth it? or the by-pass filter kit?
The kit permanently mounts on one vehicle. They cost about $200. If they do what they are suppose to, I think they would be worth it. But I don't know much about them and don't know if they're as effective as Amsoil claims they are.
What do you know about their filters? Are they pretty good?
Old 03-28-2005, 05:25 PM
BlazerLT's Avatar
AF -Advisor
Re: Amsoil
A bypass system is big overkill on any normal vehicle.
Using good oil and a good oil filter is all that will be necessary.
Fleet's use these system on some of their vehicles so they can run longer oil change intervals.
Old 03-28-2005, 06:08 PM
blazee's Avatar
Problem?
Re: Amsoil
Yeah, I think I'll hold off on the by-pass kit for a while, next time I buy a new car I'll get one for it, but 130,000 miles may be a little too late to start worrying about engine wear. I might still get one but I'll think about it a little longer.
I will join the Amsoil perferred customer club though, and my next oil change will be with Amsoil. I just used my last jug of Mobil1 when I changed my oil today. I'm still not sure which oil filter I'm going to use. I've still got three NAPA GOLD filters left, so I've got some time to decide what I want to use permanently. I'll probably only leave the first batch of amsoil in 15,000 miles and swap out the Napa filters every 5,000.
Has anyone seen any research on the Amsoil oil filters?
Old 03-28-2005, 06:17 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Amsoil
Honestly bro, there is no need to go to Amsoil.
Mobil 1 and amsoil are true PAO based synthetics and from what I have seen , you will not see any better protection with amsoil than you will see with cheaper Mobil 1.
Old 03-28-2005, 07:19 PM
blazee's Avatar
Problem?
Re: Amsoil
By joining the perferred customer program, you can buy the Amsoil at wholesale and it is actually cheaper than Mobil1.
According to tests on Amsoil's website, the amsoil out performs Mobil1. I know, I know....consider the source But I tend to believe them, because Mobil1 hasn't complained about Amsoil's claims. Also, I checked Mobil1's website and they say nothing about Amsoil. They say that they test Mobil1 against competitors, but refuse to say which ones and how they compared. Seems to me, if they thought they were better than Amsoil...they would say so.
I'm not knocking Mobil1, I have used it for years in my Impala and recently started using it in my Blazer, too. I have used it in alot of my other vehicles, too. It is a very good oil, but I think I have found something better.
Old 03-29-2005, 03:39 PM
blazee's Avatar
Problem?
Re: Amsoil
I may try one of their air filters too.
Old 04-03-2005, 02:58 PM
rudyhiebert rudyhiebert is offline
Re: Amsoil
A By-Pass is for large than 14 litre (sorry about not having the Imp. or U.S. equivilant) applications. I used it for my half-ton and drove it almost 300 k. over 19 years.
The lubricant option of the brand discussed here has an option that does not require a superior filter to get good protection, it's XL-7500.
Rudy Hiebert
Amsoil Inc. Dealer
www.lubedealer.com/hiebert
