Old 03-27-2005, 07:06 PM
91blackblazer 91blackblazer is offline
replacing rear shocks-problem
i'm trying to replace my rear shocks on a 91 4x4. Problem number one, when i unbolted the top of the shocks, the ears that the bolts fit into snapped off. Also, i've been using numerous extentions on my rachet just to get to those bolts. Is there an easier way to access these bolts?
Old 03-28-2005, 05:22 AM
ricksza's Avatar
ricksza ricksza is offline
Re: replacing rear shocks-problem
Are you saying that the ears broke off the shocks? Usually the only time these will break is when the bolts are loose.
They are a pain to do because you have to hold the nut above the frame with a wrench while loosening the bolt from under. I usually use the long entension with a socket to get the ratchet below the lower mount. That way you keep a tight angle.
Old 03-28-2005, 05:46 AM
Re: Re: replacing rear shocks-problem
no, the ear that the shock bolts to snapped off. i jb welded it back but i'm not sure if it's gonna hold.
Old 03-28-2005, 11:16 PM
AlmostStock's Avatar
AlmostStock AlmostStock is offline
Re: Re: Re: replacing rear shocks-problem
It's hard to say without seeing it but my guess is you'll need to have something fabricated and welded in.
Mark's Garage est. 1983
Old 05-03-2005, 01:59 PM
metallica21156's Avatar
metallica21156 metallica21156 is offline
i have a 95 and i had to pull the gas tank cover off to get to them. don't know where your gas tank is.
95 jimmy. Vortec V6. 4.3 liter CPI. ,2.5" catco cat, 2.5" cat back with flowmaster muffler split rear., 40 street series, 2 12" audiobahns in custom box,K&N CPI intake system.
71 Mustang coupe- project car. stock 302 with Cobra intake, holley 650dp, afco racing radiator, headman headers, msd distributor, 2.5" from the headers.C4 tranny with shift kit, Mach 1 body lay out.
90 cav, 2.2 tbi, gas getter.
99 chevy s10 zr2, 6" lift, duel exhaust. 5 speed.
