Go Back   Automotive Forums Car Chat > Dodge > Daytona
Old 03-27-2005, 08:04 PM
Stayyoung14 Stayyoung14 is offline
Send a message via AIM to Stayyoung14
Question Daytona Shelby VNT Piston/Rod
Is there any difference between a VNT Piston and Rod and a regular 90 2.2ltr piston and rod? in other words are the main engine components the same? any help would be great!!!! Thanks
Old 03-27-2005, 11:55 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Yes!
There is a big difference between the TBI internals and the internals used in the Turbo IV. The crank is forged, the rods are forged, and the pistons are cast but are lower compression than TBI pistons. The only thing that is the same is the block. The TBI crank is cast, the rods are cast, and the pistons are cast but are higher compression. Don't try to interchange those parts.
Old 03-29-2005, 11:02 AM
So Where could i find a Set of Fordged Pistons a Rods..... or if they are to rare what could i do?????
Old 03-30-2005, 03:05 PM
Polygon's Avatar
The Red Baron
Re: Daytona Shelby VNT Piston/Rod
Well, only the crank and rods are forged. The stock pistons are cast, but there are aftermarket forged options. You can head over to the Turbo Dodge Forums and head to the swap meet section and jump into the for sale section. There are members that sell stock rods and pistons all the time. Also, Turbo II pistons and rods will work in your engine. If you want new pistons and rods or you want to look at the aftermarket forged options for both check out these two vendors:
FWD Performance.
Forward Motion Inc.
I would also suggest looking at the following site called Donovan's Dodge Garage. It is a great resource of information for all the FWD Mopars:
If you don't mind my asking, what happened to your stock set?
Old 07-23-2005, 12:00 PM
93_R/T_TT_Stealth's Avatar
93_R/T_TT_Stealth 93_R/T_TT_Stealth is offline
Send a message via AIM to 93_R/T_TT_Stealth Send a message via MSN to 93_R/T_TT_Stealth Send a message via Yahoo to 93_R/T_TT_Stealth
i usually get my parts from www.forwardmotion.com
the specialize in our cars an only sell mopar
93' Stealth R/T Twin Turbo Intercooled - 24v DOHC 3.0 v6 engine - AWD AWS - 320 hp 317 lb ft. torque when I bought her unmolested hoping to be in the 600-700 hp when finished with ...
~FASTER THAN A SPEEDING TICKET~
