Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 03-27-2005, 06:34 PM
redcar94 redcar94 is offline
Question 94Thunderbird Front Brake Rotors
How do I remove the front brake rotors for replacement? There is a large nut "retainer" approx 1 1/2" that I don't know how to remove, which I believe is holding the rotor on the hub spindle. Do I pry it off to get to the nut behind or should I just loosen it with the correct size sprocket?
Please help.
Old 03-28-2005, 06:27 PM
97Bird's Avatar
97Bird 97Bird is offline
Re: 94Thunderbird Front Brake Rotors
Use a rubber or plastic hammer and hit the rotor face near the outer edge in several locations around the rotor to break it free of the spindle. I don't believe it is part of the spindle so you shouldn't have to remove the nut. When you buy the new rotors you will see how they seperate.
Old 04-13-2005, 06:02 AM
quadcells quadcells is offline
Hi,
I just did my son's 94 T-bird front brakes, they were the easiest brakes I've ever done. The rotors come off easy. Just remove the calibers and the rotor should come right off. If their is a lot of rust you might have to hit it with a hammer.
-quadcells
