Old 03-27-2005, 05:12 PM
milton666's Avatar
milton666 milton666 is offline
Send a message via MSN to milton666
white smoke...
ok the other day i was changing my oil and i noticed a leak coming from the thing you screw the oil filter in to, i took that peice off and the o-ring behind it was broken so i replaced that o-ring and put everything back together. two days later i now have massive amounts of white smoke coming out of my exhaust, could this be from improperly installing that part or is my headgasket just blown, thanks.
95' Gs-t (broke the fuck down...)
68' Mustang getting reassembled right now, 82.763% done
http://www.tagworld.com/milton666
Old 03-28-2005, 05:02 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: white smoke...
I remember Kevin saying something about crushing the oil filter housing. I guess it is water cooled and if you torque the oil filter down too far you will crush the passages and allow the oil and water to mix. Might want to check that out first, because it's much cheaper than a HG.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 03-28-2005, 09:15 PM
milton666's Avatar
Re: white smoke...
allright, i did kinda torque my oil filter down pretty hardcore, hope thats it, thanks
Old 03-28-2005, 09:39 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Re: white smoke...
oil filters don't need to be cranked on... screw it on until it is seated and then give it a 1/4 turn.... if it isn't tight enough it will leak a little... if that happens... give it a little more twist...
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 03-28-2005, 09:43 PM
milton666's Avatar
Re: white smoke...
yea i know, usually hand tighten, then half turn, but for some reason i decided to tighten it as far as i could, have no idea why now, but if this is where my problems coming from, will i have to get a new filter? did i screw this one up or if i just loosen it should it fix the problem (if this is whats causing it)
Old 03-28-2005, 11:29 PM
cursed1g cursed1g is offline
Banned
Re: white smoke...
thats why i hand tighten my filter
Old 03-29-2005, 10:13 PM
Re: Re: white smoke...
No.....It will be more involved than that, but less involved than a HG. You will need to replace the oil filter housing, drain both the coolant and oil and replace the filter. It sounds like you cracked the passages that allow the antifreeze to circulate around the oil, which, in turn allowed the oil and coolant to mix. So loosening the oil filter won't do anything.
It sounds like you have some work ahead of you, but much less work than a HG.
1997 Spyder GS-T
5-Speed
Old 03-31-2005, 09:17 PM
milton666's Avatar
Re: white smoke...
turned out it was just my turbo dying...ive got another thread about it, gettin an evo 16g now
