Old 03-27-2005, 03:59 PM
crv-tec crv-tec is offline
Calipers...
As we know I am planning to re-do my entire brakes. The stock HF brakes aint good enough. I've gotten the price to do the rear disc conversion (minus pads, lines and rotors), and the price for everything to go onto front LS brakes. But I was wondering if using four piston calipers up front would make a large difference compared to using just the standard two piston caliper. Also does anyone know of any sites that have a walk-thru/explaniation of how to swap the fronts from HF to LS?
'nuff said
Old 03-27-2005, 04:55 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: Calipers...
i didnt know ls brakes came wiht 2 piston calipers. i thought it was only 1
Team Lonely Drivers
Old 03-27-2005, 05:14 PM
steve-o317 steve-o317 is offline
Send a message via AIM to steve-o317
Re: Re: Calipers...
^^im with him only 1 piston
but i also am wondering how big a difference the integra brakes are because i might do both front and rear
89 std hatch back
D15B1 4 speed
MPFI Swap
CAI/4-2-1 Header/soon to come custom 2 1/4" cat back
NEW!! 15" rota slipstreams flat black with 205/50/15 falken ziex ze 512's
Old 03-27-2005, 05:23 PM
Scott82 Scott82 is offline
Re: Calipers...
There is a book on amazon.com that tells a little about it. It's called honda engine swaps and oem upgrades, but on the cover it just says honda engine swaps
Old 03-27-2005, 05:25 PM
Re: Calipers...
i think you do have to convert the whole thing if you are going to do it, b/c the proportioning valves are differ, and the master cyls and boosters too., you also have to get the differ ebrake cable, ect.
Old 03-27-2005, 05:42 PM
Re: Calipers...
Yea your right, they are one piston, got stupid for some reason. I'm pretty much going LS all through the break system. Since the prop vavles are different from the HF I decided to go ahead and just do LS up front so i could have some slightly bigger rotots.
So I guess my question os would having the two piston calipers up front also improve braking? Or should I stick with one piston?
'nuff said
Old 03-27-2005, 10:13 PM
icE_x's Avatar
icE_x icE_x is offline
Send a message via AIM to icE_x
Re: Calipers...
i don't think the difference would be that noticeable - stick with the 1 if it's easier
1990 Civic EX 4-Door Sedan - D16A6 - 204k miles
:: working on mechanical and cosmetic restoration ::
