Go Back   Automotive Forums Car Chat > Ford > Probe
Old 03-27-2005, 02:11 PM
bhoward86 bhoward86 is offline
Question Back middle Spark plug smokes???
Yeah for some reason my back middle spark plug starts to smoke after engine has been running for about 5-10 min. What could be causing that?
Old 03-27-2005, 02:15 PM
joshs93gt joshs93gt is offline
Send a message via AIM to joshs93gt
Re: Back middle Spark plug smokes???
i'm not sayin this is for sure, but check to see if you have oil in your plug wells. oil in the plug wells could be cause by a leaky intake manifold gasket. again not possitive on this, but it's worth a shot.
Old 03-27-2005, 02:18 PM
I'm a novice at cars so where would the plug wells be?
Old 03-29-2005, 09:37 PM
shawnwilliams's Avatar
shawnwilliams shawnwilliams is offline
It might just need a new plug, and if you look were your wires are attched to the motor, and pull one off you can see the plug. It easily goes back on dont worry.
Old 03-29-2005, 09:38 PM
It might just need a new plug, and if you look were your wires are attched to the motor, and pull one off you can see the plug. It easily goes back on dont worry. OR other word the plug wells are were the spark plugs are.
Old 03-29-2005, 09:42 PM
Well I just had all the spark plugs replaced bout a month and a half ago. The back middle spark wire is the only one that kinda jiggles and I tried tightening the spark plug.
sorry for some reason it sent 2 and i cant delete it
Old 03-29-2005, 09:47 PM
maybe the seals gone were that sparks is.
Old 03-29-2005, 09:48 PM
Best bet is to take it to a pro, before something really bad happens to the engine, or something catches on fire.
Where would the seals be and would it be replaceable?
Old 03-29-2005, 09:51 PM
at the end of the screw in part prob, not 2 sure, but u might of tightened to hard and broke the seal.
