Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 03-27-2005, 12:50 PM
Bluegem Bluegem is offline
camber kit Question Please help!!!!
Do i absolutely need a camber kit if I lower my car 2" and what springs do you recommend for a comfortable ride? I have a 94 honda civic dx and I just want a more agressive look.
Old 03-27-2005, 04:16 PM
BullShifter's Avatar
Re: camber kit Question Please help!!!!
No you don't need camber kits but be ready to buy A LOT of tires. Camber kit's are a whole lot cheaper than a few set of tires.
More than 2" I recommend adjustable coilovers like H&R or Tein, you could also go with Ground Controls and Koni Sports. When you lower around 2" you need to buy the best parts you can afford or you will regret it in the long run.
Old 03-28-2005, 05:17 AM
Re: Re: camber kit Question Please help!!!!
do you get a better ride with springs than the adjustable coil over.
Old 03-28-2005, 05:19 AM
Old 03-28-2005, 08:06 AM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
In most cases yes. Lowering springs just lower the car a little bit so the spring rates are not very exreme. Coilover springs need to be stiffer because most people drop the car alot and you need a higher spring rate to prevent damage and bottoming out of the shocks.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
Old 04-02-2005, 09:41 AM
kingdave123 kingdave123 is offline
Re: Re: Re: camber kit Question Please help!!!!
next weekend im installing omni full coil over and upper arm adjustable ball joint camber kit as well as the rear shim camber adjustments. are there any tips i may have overlooked? i pretty much know what im doing but never done on a honda before (i have a 98 civic ex d16y8) are there any tricks to get camber correct without being too time consuming? i plan on taking my car to a alligment shop after all is set up to get my toe corrected (im sure ill throw that all off). any help would be awesome. thanks.
dave
Old 04-02-2005, 11:29 AM
Re: Re: Re: Re: camber kit Question Please help!!!!
dave
#1 Tip - Get some good penatrating oil and soak all the lower strut bolts now, so you have less of a chance to end up with seized bolts. Not a bad idea to spray the uppers too but those usually are pretty free.
To get the camber correct let the people doing the alignment worry about that. It's not a bad idea to leave a little negative camber in it. For mostly street use i suggest no more -2.0 degrees. A little more in the back then the front, for instance -1.5 front -2.0 rear.
Corner weighting the car is also a very good idea. that balances all 4 corners, easy to do with adjustable coilovers. That will need to be on scales.
Keep in mind every time you change the ride height, alignments and corner weighting should be done.
Old 04-02-2005, 11:59 AM
when i bring it to the alignment shop do i just ask to do 1.5 front and 2.0 back (negative)? and since this is going to be entirely a street application could i estimate on the corner weighting by some trial and error? drive it cornering in both directions, stopping and starting to get an idea of where force would need to be applied? is that even possible? never done a full coil over so i havnt entered the realm of tuning the spring rates and such. btw, thanks for the tip about cambering at the alignment shop. i would have attempted that my self. haha. thanks.
dave
Old 04-02-2005, 10:28 PM
Most shops will only align to factory spec's, you will need to find a performance shop. For street use strictly, factory spec's will work ok.
I don't beleive or see how it would be possible to balance a car without being on scales.
