Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 03-27-2005, 11:39 AM
MLella05 MLella05 is offline
Strange noise and starter problem
got 2 questions...
just installed a new starter old one was grinding when you turned the key after a couple times it would start and run fine.. checked battery its fine also the new one is still making the grinding noise and will still start eventually but when its running it makes a noise almost like a penny in the vaccum cleaner, something rattling around it never did that with old starter....
so why is it still grinding and what is that noise....
i took the new starter off and looked at it cant see anything loose and all teeth are on fly wheel any help would be useful thanks in advance
by the way 92 88 royale
Old 03-27-2005, 02:13 PM
diesel1962 diesel1962 is offline
Re: Strange noise and starter problem
Sounds like starter pinon gear is engageing with the fly wheel.Or the bendix spring is not pulling pinion gear all the way back.Do thoes starters require shims? I know the older olds bult engins required them when replacing starter.I have not yet had to replace my starter,(94 Olds). Let me know what you find out..Good luck!! Happy Easter!! Diesel1962
Old 03-27-2005, 05:47 PM
i dont know anything about needing shims i took off the new starter had it tested it was good put it back on and car wont start at all im taking it to a shop
Old 03-27-2005, 06:53 PM
i just heard from friend about shimming starter can anyone tell me whats that about
Old 03-28-2005, 02:55 AM
Hansnet's Avatar
Hansnet Hansnet is offline
It IS CRUCIAL to make sure it is shimmed right. Go out RIGHT NOW and buy a chiltons manual at any local parts store, if they dont have that get a hayes.
Not sure if you have ever built a house before but if you have even installed a door in a house you know how important shims are, starters are no different, it needs to be aligned PERFECT with the flywheel.
GET A CHILTONS MANUAL FOR YOUR CAR NOW.
Old 03-28-2005, 09:17 AM
atv087 atv087 is offline
Send a message via AIM to atv087 Send a message via Yahoo to atv087
yea chances are you need so shim it and if you left it like that for a while you could have caused alot more damage
