Old 03-27-2005, 09:34 AM
David John David John is offline
To much Tranny fluid
I was just wondering out of curiousity is putting a little too much Tranny fluid bad? I mean will it hurt the tranny at all?.......Thanx
Old 03-27-2005, 11:43 AM
16th hippy 16th hippy is offline
on an automatic, i've seen where WAY too much can blow out the valve body, or it could just swell up and blow the seals....depends on how much the "to much" is.
On a manual, is sorta the same thing, except there is no valve body in it....in most cases, if the vent hole is not plugged up, it will just come out of there until the pressure of the extra fluid is relived. If the vent hole is plugged, and there is way to much fluid, it can start leaking at the seals as well.
Old 03-27-2005, 12:20 PM
OverBoardProject OverBoardProject is offline
Banned
Re: To much Tranny fluid
it's really a bad thing to put too much oil in anything... It overpressurizes whatever you put it in.
Plus oil does expand when it gets hot making it even worst yet
Old 03-27-2005, 01:07 PM
xtrememeasures10 xtrememeasures10 is offline
Send a message via AIM to xtrememeasures10
Re: Re: To much Tranny fluid
Yeah id craul under it and drain it out til its in the safe range after you have ran it through the gears a couple times. Just make sure when you check it the truck is running and you have ran it through the gears a couple times that way you get out any air pockets.
Old 03-27-2005, 04:09 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Over filling a tranny is really bad.
But remember, you check the tranny fluid when the engine is running.
If there is too much, have someone put one of those pumps down the dipstick hole to pump a little out or consider this a great time to go get your transmission flushed and refilled with new fluid and a new filter.
1995 Factory Blazer Service Manual for sale, PM if interested.
