Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 03-27-2005, 09:03 AM
Ranger 1 Ranger 1 is offline
no start 87 2.9
I have an 87 4x4 2.9. I know that the fuel system relay is not energizing. Both fuel pumps work, have changed the relay, even changed the cpu. The only way I can get it to energize the relay is to go to the test plug on the left fender well and run a ground from the far right terminal to the battery ground. The way I figure it is that there is a ground not making a connection. I can't remember if I ran a gnd from the battery to the gnd next to the computer or not. The other cpu i hav is used (and is the same numbers)- is ther a chance that it could have the same problem? Please help
Old 03-28-2005, 08:57 AM
Psychopete Psychopete is offline
Re: no start 87 2.9
I believe the ECU needs two grounds. There's one in the cab and one directly from your battery. Are these both hooked up?
Old 03-28-2005, 08:26 PM
Re: Re: no start 87 2.9
The one in the cab is grounded from the wiring harness next to the cpu to the cab. I will check the ground from the battery tomorrow. The gnd from the battery should go to the frame-should there be another gnd from the battery terminal going into the harness back toward the cpu? I came to the conclusion that the problem should be a gnd problem.
Old 03-29-2005, 07:11 AM
Re: Re: Re: no start 87 2.9
Yes that is correct, you should have a nicely sized ground going to the frame. You also have a smaller 14-12? gauge wire going from the battery into the main harness that goes to the ECU. Look for a black plug that's not hooked up kind of near the alternator/passenger side..
Old 03-30-2005, 07:16 PM
Pete, you are a genius. That was the exact problem. We were pulling stumps out and the battery had just enough movement to pull the plug apart.
Thanks again, Brian
