Old 03-27-2005, 08:26 AM
Jag Man Jag Man is offline
Question 1993 Buick Lasabre
Front driver's window stopped working, on cold days ,did not work until interior was warmed up.Then grinding noise was heard for a few days. Now window in up position and will not move.
Is it the motor ?,or track problem? . What to look for before I purchase a new motor.
Also door panel removal,how to remove without causing more problems.
Need help asap... Thanks Jag Man
Old 03-29-2005, 11:15 AM
buickmastermind's Avatar
buickmastermind buickmastermind is offline
Re: 1993 Buick Lasabre
If the grinding noise was metal on metal, then likely it was a motor problem. But, if it sounded like plastic, or glass being gritted against something, then it might be the track.
The door panels usually have several screws hidden from sight that will need to be found. Usually they are on the armrest or by the handles. The panel is also held on by what appear to be plastic screws that pop off but prying them with a screwdriver between the panel and the door.
To be sure what the problem is, you will have to take the panel off the door.
1986 LeSabre Limited L67 sleeper
Fully ported & polished, shift kit, CAI, F41 polyurethane suspension, headers & 3" exhuast,
Old 03-29-2005, 12:05 PM
Wink Re: 1993 Buick Lasabre
Thanks for the help ! It's the metal to metal noise ,no doubt it's the motor,Some one mentioned door panel removal......
Door panel removal was found by taking out the red plactic lens,(2 10mm screws) need to remove the arm rest with the controls to get at the other 2 screw again 10 mm. It sound easy enough ,I'll try do do this project within the next 2 days.
Old 03-31-2005, 11:02 AM
rustbucket rustbucket is offline
On my 99, the motor engages a sprocket (sort of looks like a sprocket on a bicycle) Possibly the gears are stripped. The motor itself should not make much noise. (new motor $72 at autozone)
