Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 03-26-2005, 11:12 PM
HardJeans HardJeans is offline
Send a message via AIM to HardJeans
Headlight switch
This should be a fairly simple answer. I took my dash off so I could install an mp3 player in my '92 Ford Thunderbird, and when I took my headlight switch off, I just pulled it straight out. Now when I try to put it back on, it doesn't seem to hold. Is there a trick to it, or do I have to buy another one, or did I break something? I know I'm gonna feel stupid when I get the answer.
Thanks!
Old 03-27-2005, 12:16 AM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
Re: Headlight switch
thats weird, I tried once to get the gauges out of an 89-92 car, with the headlight pull style switch. To get the trim off, I had to take that knob off. For the love of god, I couldnt get it off, after failed attempts of pulling/yanking/yanking with pliers/hammer ..i finally said screw it. If its the plastic knob that isnt staying on, just try and superglue it back on.
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 03-31-2005, 10:12 AM
SAM89 SAM89 is offline
there's a little black clip that goes inside the headlight knob , on mine it slipped down the shaft, be shure to get it all the way back in the knob.
