Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 03-27-2005, 12:07 AM
bwhuot2 bwhuot2 is offline
Removing the idler pulley
Is the bolt to the pulley a reverse threaded bolt or is it a typical bolt that unscrews counter-clockwise?
Old 03-27-2005, 01:29 AM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: Removing the idler pulley
just did some quick research, i see nothing saying it is. commonly, if a bolt is reverse threaded, its labed/stamped/marked nearby (IE- the radiator fan blade bolt). however the bolts may have locktight on them. if you are having trouble make sure you are using the proper METRIC 6-point socket size, if all else fails, use a breaker bar. if you need more room for clearance, you may want to CAREFULLY unbolt the top mount and lift the engine a few inches.
Old 03-27-2005, 01:13 PM
dardena53 dardena53 is offline
Hello, I just removed the idler pulley from my cover, and it is NOT a reverse thread.
