Old 03-26-2005, 09:02 PM
nickydontcutem nickydontcutem is offline
Question Help with alternator
I have a 96 GST 5spd, and this is my first time replacing the alternator. I got it off pretty well, but my problem is putting the new one on. I'm stuck where you have to mount the alternator to the bracket. My question is does the pivot bolt fit into the little slot on the bracket or can you have it in any position? I would like to know so I can finish putting it on. This is puzzling me because I put the long bolt in first to hold the alternator in at the bottom, then I put the belt back on, and then tried to mount the alternator on the bracket. But, it seems like the pivot bolt will not sit flush on the bracket. Someone please help me with this problem because I am a newb to this. Thanks, my name is Mike.
Old 03-26-2005, 09:45 PM
Talon69's Avatar
Talon69 Talon69 is offline
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
Re: Help with alternator
just loosen the pivot bolt enough where the alt will drop to put the belt on the tighten the screw up to bring the alt up.
Old 03-26-2005, 10:20 PM
SLoe's Avatar
SLoe SLoe is offline
You took the whole alt. off to change the belt? If that bolt is not flush, then you have the thing upsidedown. Hopefully this crappy pic might help.
[IMG][/IMG]
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 03-26-2005, 10:45 PM
SLoe's Avatar
This is the wrong way. I hope I am talking about what you mean.
[IMG][/IMG]
Old 03-26-2005, 11:14 PM
No, I did not take the whole alternator off to change the belt. I took the whole alternator off to put in a new alternator and my problem was putting it back on. I'll try again tomorrow and see what happens. I was having trouble getting the correct position of the pivot screw.
Old 03-27-2005, 09:46 AM
SLoe's Avatar
If you are talking about the square headed bolt. It does sit flush. Here is another crappy pic. I am just trying to help.
[IMG][/IMG]
Old 03-27-2005, 01:48 PM
No I am talking about the bolt you have in the first picture. If you could get a better pic, it would be appreviated.
Old 03-27-2005, 03:54 PM
SLoe's Avatar
Here is the best I can do in the rain.
[IMG][/IMG]
Old 03-27-2005, 08:44 PM
Thumbs up
Thanks I've figured it out.
Old 03-27-2005, 08:49 PM
SLoe's Avatar
I stood out in the rain for those pictures, did they help ;^)
Old 03-28-2005, 08:08 PM
Thumbs up
Those pics helped a lil bit, but thanks though, much appreciated.
