| Let's get Technical! Discussion for hardcore in-depth motor heads! |
SCS Short Connector
I am trying to do a self-dyno, i am trying to find out what the scs short connector/scs service connector and where it's at. I have an engine check light problem.
Re: SCS Short Connector
self dyno huh ?
meaning self-diagnostics
so no one here know what that is?
Year and make of car?
1996 Acura Integra LS 3 Door
that would be obd 2 my friend.
94' Del Sol VTEC (B16A3) SOLD. Accel plug wires, NGK iridium IX plugs, AEM short ram intake, DC sports ceramic coated header (4-2-1), Airmass high flow cat ,Custom Magnaflow exhaust, Bosal Brospeed tips, Neuspeed short throw shifter, Tokico clutch master cylinder, Tokico clutch slave cylinder, Prothane complete kit bushings, Brembo front rotors, NR EL-Glo instrument gauges, CTR LSD trans with ITR final drive, Exedy chromoly flywheel, ACT HDSS clutch kit, Raxle axles. |
obd?
If your looking for the service connector so you can pull CEL codes, it is located underneath the passenger side kickpanel next to the ecu. It is a two-wire connector and it is usually is in a green rubber cover. Sometimes it is taped up under the glove box. I hope this is what you’re looking for.
Re: Re: SCS Short Connector
