Old 03-26-2005, 08:03 PM
justin_t_ justin_t_ is offline
Lowering Hot Wheels Cars
Does anybody know how to lower the hotwheels models?
The model i have is the hot wheels BMW 645ci with no springs
What other modifications do you think i should do to it? i wanna put rims on it but no sure what kind will fit
can anyone please help?
thanks
Old 03-26-2005, 08:11 PM
mod mod is offline
Re: Lowering Hot Wheels Cars
does your model have springs or is the wheel assembly skred on to thr frame
Old 03-26-2005, 08:13 PM
mod mod is offline
is the wheel essamblies skrewed on eith a spring or no spring
Old 03-26-2005, 08:57 PM
Gafoto's Avatar
Gafoto Gafoto is offline
Send a message via AIM to Gafoto Send a message via MSN to Gafoto
Re: Re: Lowering Hot Wheels Cars
With hot wheels you're gonna have to do some cutting. Give us exactly what car you want to lower and we may be able to help you out more specifically.
Old 03-26-2005, 10:40 PM
KustmAce's Avatar
KustmAce KustmAce is offline
Grande Boleros de Fuego
Depends on the car. If it has a portion in the plastic chassis you can cut out, then just get an exacto and trim out some of the plastic. That will lower it. If not, good luck.
MAKE ART, NOT WAR
Old 03-26-2005, 10:42 PM
ModifiedCars ModifiedCars is offline
Send a message via AIM to ModifiedCars Send a message via MSN to ModifiedCars Send a message via Yahoo to ModifiedCars
what Sckizzale?
Old 03-27-2005, 02:46 AM
The model i have is the Bmw 645ci, which doesnt have springs, its just an axle and plastic.
Old 03-27-2005, 07:14 AM
mod mod is offline
then u cut the plastic off where the skrew goes in dont trim to much do small portions and test it
Old 03-27-2005, 08:37 PM
dont understand that
Old 03-27-2005, 09:28 PM
Gafoto's Avatar
I'm not exactly sure what the setup is like, can you disasemble the car and get some pictures? Anyone else have this car? I can' help you if I know how the wheels are held in there.
Old 03-27-2005, 09:32 PM
this person has the same car in this forum, heres the link to it, it shows parts of the chassis http://www.diecastxchange.com/forum1...howtopic=17145
Old 03-28-2005, 04:46 PM
KustmAce's Avatar
Oh, I thought you were talking about like, little Hot Wheels, like 1/64th.
I dont have any larger scale Hot Wheels cars, so I cant help ya. Sorry
MAKE ART, NOT WAR
Old 03-28-2005, 05:35 PM
supradriva01 supradriva01 is offline
i helped my friend out with that same exact model its a 1/18 right if it is we used 1/24 import racer wheels
Supradriva01
Old 03-28-2005, 07:46 PM
nosliw2004's Avatar
nosliw2004 nosliw2004 is offline
Send a message via AIM to nosliw2004 Send a message via Yahoo to nosliw2004
o its a 1/18 now i get it cuz i never thought hotwheels made a 1/64 645ci
Old 03-31-2005, 12:11 PM
ElRxBandito's Avatar
ElRxBandito ElRxBandito is offline
Heh, the wonderful process of lowering HotWheels cars, heh, alright, I should make a tutorial about this one later, alright, what I do is, I just cut the entire skewer where the spindle screws to the frame, then I drill a small hole where it used to be, then attach a spring along with a small little rod (to guide it up and down with out shimmy'ing around too much) then glue the spring to the axle and the chassis, then from there, you can use any axle/wheel combo you want as long as it still fits.
Tutorial to come.
I'm back!
