Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 03-26-2005, 04:41 PM
pjmax0 pjmax0 is offline
Right Headlight Dimmed
Right headlight was dimmed, and changed the bulb--with the same result. Checked all the wires everything seemed fine and the bulb didn't get any brighter. What else could be the problem?
Old 03-27-2005, 12:18 AM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
Re: Right Headlight Dimmed
may sound stupid, but could it be a dirty lense? Check the fuses too.
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 03-27-2005, 12:29 AM
flewthecoupe's Avatar
flewthecoupe flewthecoupe is offline
Did you look inside the connector itself at the contacts where the headlight plugs in? They may be correded and cause the problem.
It's not how fast you can go, it's how fast you can get there.
Proper grammar, it's not just for English teachers.
I don't pick on any one person, I treat everyone this way.
My only pleasure is tormenting those people who work for me.
There are no stupid questions, just a lot of inquisitive idiots.
Old 03-27-2005, 05:32 PM
97Bird's Avatar
97Bird 97Bird is offline
It wouldn't be a fuse problem. As flewthecoupe said, check the contacts for a good clean connection and if they are good then check the ground connection.
Old 03-27-2005, 06:05 PM
thunderbird muscle's Avatar
thunderbird muscle thunderbird muscle is offline
The fuses could be corroded to, which would limit the amount of current that would flow through, but i would think it would cause both to dim.
A founding member of HNF car club!
Do you know what it feels like to do an amazing burnout listening to that wonderful exhaust note, Oh you drive a honda sorry dude, but theres hope they still make nitrous oxide!
Racing a Honda is like being in the special olympics even if you win your still retarded!
Old 03-31-2005, 03:04 PM
97Bird's Avatar
All the lights on that fuse would be dim if the contacts were corroded.
