1987 ford thunderbird
hello everyone, i have this problem that i can't figure out.my 87 ford thunderbird cuts off after you crank it up.it has a 3.8l v6 fi.when you first crank it,it idles wide open then when you put it into gear it cuts off.some say it might be o2 sensors bad,some say this and some say that please help.
Re: 1987 ford thunderbird
that wide open scars me i dont know what to tell you about the stalling.but the wide open:can be the cruise control if the vacum box breaks in the drivers side fender it will cause it to go wide open i dont know if thats you problem but if it is you can cut the cable for cruise cotrol going to the throttle body.oyea take the intake hose off the thottle body and look at the butter fly if its stuck on wide open thats your problem.
I learn that the hardway a few years ago i was racing in a stock enduro w/a '87'T-bird 5.0L i got into a bit of a wreck on the track and the car went into wide open throttle i thought a motor mount broke til i brought it home and figued it out. |
also another website you can try is www.foxthundercats.com.
it speacalizes in 83-88 fox t-birds/cougers/LSC try there forum |
If his butterfly was stuck open it wouldn't die when he popped it into gears, it would be like doing a nuetral slam. Its probabaly one of your sensors, O2 might do it, but I don't think so, the one I'm banking on if your TPS or your Ait meter... I think your car uses the VAM not the MAF shoudl be a box inline with your intake right after after the airbox I think. Those would most definealty do that... also it could affect the engine in such a way that it might cut off the strain is on it.
hello everyone took t-bird to shop and they have changed every sensor on top,side,back and front of engine.they put computer onit and it stills shows everything bad.if anyone has an idea what it is please help.
