Old 03-26-2005, 02:44 PM
mkile16 mkile16 is offline
Lightbulb 96 grand am dash repair
hey i have a 96 grand am SE. I have been trying to dismantle my dash because my cigarette plug had come undone. All i need to do is screw it back into the wire that it was plugged into before but I cant seem to get the dash apart. After i think i have taken all the screws out there always seems to be something else i have to do and i dont want to screw anything up so i just put it all back together. How can i do this?
Old 03-26-2005, 03:34 PM
kallenbach_05 kallenbach_05 is offline
there should be 2 screws below the radio back in a compartment, remove those. there will be 2 more screws above the gages. those are the only 4 screws holding it on as well as clips. just use from force to undo the clips when the screws are out and it should come off to allow u to get to the cig. lighter
Old 03-26-2005, 04:48 PM
Hoags's Avatar
Hoags Hoags is offline
Re: 96 grand am dash repair
If you try to remove the dash bezzel all of the way, I have found it a little easier to tilt the steering wheel all of the way down, it helps to give a bit more room. You will need to use force to get it out, but be careful, too much force and you could break/crack the thing.
Good luck.
Old 03-26-2005, 10:20 PM
justin0717 justin0717 is offline
Also put the shifter all the way into first(if auto) and set the e brake..this makes it easier as well.
1996 GA SE 2.4L- sold
1999 GA SE 3.4L - newest
