Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 03-26-2005, 01:32 PM
JJ302 JJ302 is offline
Cooling Fan Troubles, Help!!!!!!!!!
Help! My Electric Cooling Fan Is Not Running At All On My 86 Cutlas Ciera,keeps Overheating, Not Sure What The Problem Is, If Its The Computer, The Wiring , Or The Fan Itself,, What Can I Do?
Old 03-27-2005, 03:32 PM
mike5721947 mike5721947 is offline
Send a message via AIM to mike5721947 Send a message via MSN to mike5721947
Re: Cooling Fan Troubles, Help!!!!!!!!!
i have the same problem as you you will want to go and use jump wires straight from the 2 plugs on fan to the battery, if it runs your fan is still good if not replace it. if it worked i cant help you more if you dont give me what engine you have i have a 2.5l 4 cylinder in my 86 ciera. ended up somehow getting my cooling relay to smoke and short out so im having to replace it. we ended up having it wired permenently on for a bit and am now wanting to get it running correctly. i am having to replace the wiring connector to the cooling relay on the shock tower from a wire being piggybacked on another and it shorting out. luckily this happened in my driveway, not on the road.
get a hanzes or chilton manual for the car, it helps alot with these cars. (i have both)
ps ended up getting a used connector to my relay from a wrecker because the price of it is 35 bucks CND dealer net. and the relay is 8 bucks dealer net. there both coming in to my work tomorrow and hopefully my car will run in the next few days.
EX-Owner of a grey 1986 Oldsmobile Cutlass Ciera Brougham
its gone towards the kidney foundation car autions.
EX-Owner of a blue 1991 pontiac firefly turbo
Now own a 1990 suzuki sidekick 3" lift, 235 A/T's winch bumper, and way to many km's.
also a beater hyundai pony from way back in 1985
Old 04-02-2005, 10:16 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
I just went through this today. First check the bottom lefthand fuse in the fuse panel in the glove box...it's the juice to the fan...if it's ok then go under the hood..
Stick a safety pin through the electric fan black wire w/red stripe and jumper a 12 volt wire to it from the battery..if it jerks or tries to run, it's good and you can go on to the next test. If not, the fan's bad.
At the front of the motor/drivers side and screwed into the side of the head is a squeeze the sides, round pin connector with a green w/white stripe wire. Turn the keyswitch on, connector a jumper wire from the pin inside the connector to a good ground on the motor. The fan should come on. If it don't, the fan relay, mounted on the inner fender panel/drivers side, is likely bad. The good news is most autoparts stores stock it...about $10.
If the fan comes on, the the device screwed into the block, Cooling Fan Switch, is likely bad and nes to be replaced...another $10.
It's un-nerving waiting for the fan to finally come on but it will in a few minutes.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 04-02-2005, 11:16 PM
ya we ended up changing the cooling fan relay someone butchered the wiring and the relay (the relay on the driver shock tower) fried and so did the connector and then nerrowed it down to the cooling switch (the part that screws into the front driver side of the block) and ordered one straight from GM (i work at a dealer so its fairly cheap) so its now running strong!
but i still have a problem with the power windows (they arnt in proper order from front to back, its pass-front, pass-rear, driv-rear,and finally driv-front) is that the proper order or is it just me?
Old 04-03-2005, 08:20 PM
AF - Advisor
I don't know...mine's a armstrong :>]
