Go Back   Automotive Forums Car Chat > Saturn > General Discussion
Old 03-26-2005, 01:02 PM
kevin1968 kevin1968 is offline
idle 1997 dohc 1.9
hi have changed out engine temp control sensor but still have high idle .If anyone could tell me how to lower idle that would be great.
Old 03-26-2005, 04:26 PM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: idle 1997 dohc 1.9
what is idle at? did you reset the PCM after swaping the ECT? are you burning oil? any other driviblty problems?
Old 03-27-2005, 10:27 AM
Re: Re: idle 1997 dohc 1.9
Hi thanks by reseting the Pcm all I have to do is disconnect the battery right,if so I did this.Also not burning any oil,and car idles at between 900 to 1200rpms.Also when going to stop sign the idle will jump up then go back down .
Old 03-27-2005, 11:21 AM
mysatilac's Avatar
mysatilac mysatilac is offline
Most people don't reccomend this, unless you think it has already been messed with, but i've done it for my car a couple of times with no problems and it does work.
On your throttle body there is a small torx head screw by itself towards the front/bottom (sometimes covered by a plastic plug), you can turn it counter clockwise just a little at a time and this will back your idle down.
if you look at it you can easily understand how this works, it moves the throttle valve/plate rest position slightly when you have no tension on the throttle cable.
It's beautifully destructive isn't it,
'97 Maroon SL1- Bored Throttle Body, Knife Edged Throttle Plate, Short Ram Intake 3" Cone Filter, Flip Flop Trunk, Red Enameled Engine, Interior & Exterior Painting Mods, 4" Burnt Tip Muffler, DRLs ON A SWITCH!, "Rims", Seat Covers, And A Stereo System Thats Too Good!, Other various mods and detailing...
Old 03-27-2005, 04:54 PM
^^^ i do not recommend that ^^^
an easier way of reseting the PCM is to pull the PCM B fuse. try it then post back. but i don't concider 900-1200 bad in any means, thats about where i keep mine.
Old 11-07-2005, 04:29 PM
drew300 drew300 is offline
My sohc had the intake gasket fail, and the vacuum leak raised the idle.
You can check the gasket with some throttle body cleaner. Just lightly spray around the intake/ head area. If the revs come up, you've got a leak.
Old 01-24-2006, 10:26 AM
Washer Fluid Washer Fluid is offline
even if you do this the PCM will still set the idle where it wants it
Signature?!? I don't need a stinking signature
