Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 03-26-2005, 01:32 PM
limewire limewire is offline
Send a message via MSN to limewire
Leaking Front Diff.
Well I finally got my Jimmy up on ramps to take a good look at what was leaking, turns out my oil cooler lines are fine but discovered a worse problem. My front differental is leaking from all three seals. So my question is do I have to take the diff right out of the truck? Or can I change them right underneath the truck without removing it?
Old 03-27-2005, 09:55 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Gotta remove it... Not that difficult... About an hour to remove it for a 1st timer... Use a jack to lower it though, and use wood on the jack, the walls of the casing on those are fairly thin...
Old 03-27-2005, 10:34 AM
pies pies is offline
Re: Leaking Front Diff.
make sure to check the vent for the front diff.
Old 03-27-2005, 11:40 AM
front diff.
I suppose the vent being clogged created enough pressure to blow the seals?
I'm assuming a shop would be expensive for this type of job?
Old 03-27-2005, 04:33 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
by repairing the vent, you might stop the leak altogether.
I have yet to hear about people blowing all three seals at once.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-27-2005, 06:47 PM
diff leaking
Well were the drive shaft comes into the diff. it is leaking badly and the left and right seals have a very small leak. How do I clean the vent? Thanks for any tips.
