Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '91 - '96
Old 03-26-2005, 11:50 AM
pro47 pro47 is offline
posible electrical problem
I have a 95 Jetta that when you start it the daytime driveing lights flash and tha gauges are dead if you rev the engine the gauges come to life and the lights stop flashing I have checked just about everthing ie grounds and charging system and and they check good it is about to drive me nuts does anyone know what the problem might be
Old 03-26-2005, 06:10 PM
boschmann boschmann is offline
Re: posible electrical problem
If you're sure it's not a connection problem then get an alternator ripple (or diode) check. The alternator can be charging & have a bad diode.
Old 03-26-2005, 07:54 PM
i think it also has had the ignition switch replaced because the door and the ignition have 2 dirrerent keys do you think the switch could be bad???
Old 03-27-2005, 07:17 PM
It's possible, but I don't see how revving the engine would affect it. If you can jiggle the key & it changes then I would suspect it more. Do the lights flicker rythmically or just flash on & off randomly?
Old 03-27-2005, 10:23 PM
they flash in rythm untill you rev the engine then when everything comes to life they stop flashing. i really appritiate all your help thank you
Old 03-30-2005, 08:55 PM
Still sounds like a charging/alternator problem.
