| Cosmetics interior, exterior, wheels. |
How To: New Front Grille (long)
Props to Daniki? for the inspiration on this one. I finally got the urge to fill the large gaping holes in my front bumper after the mods I did to it when Installing the WW lip.
So I went to the local home depot and picked up two 1/2" X 12" X 24" expanded metal lathe sheets, you know the stuff for barbeques and began hacking away. First off, it really helps to have a good industrial belt sander, tin snips, a welder, and about 8 hours of time to kill. To make the lower portion I had to fabricate a mounting bracket that bolts onto the lower frame of the car. There are some convenient holes there that I hd to re-tap to accomodate some screws I had (1/4-20). You can see the bracket and front fillers that are there hanging waiting for the paint to dry. I rough cut the metal oversize and bent it to shape, then welded on some tabs to mount to the bracket. There is an image of the assembly out of the car. The front grille was a pain in the @$$!! Lots of sanding/grinding to get it fitting right and figuring out how to mount it. I finally got it to fit good, and luckily the existing mounting tabs happend to be inline to weld some long screws onto the back of the grille. I also had to weld some tabs on the top to keep it in and put in a set screw right behind the hood latch to keep it in place. Not to mention the minor hood mods I had to do to get it to stay in place. Trust me, a lot of work but well worth it. So far it looks solid and Ill check in a couple of days to see if the screws loosen.
P@ - www.customsteel.com Red 99 G20(t) / UR 2 piece / JWT POP / HS CAI / WW Lip / HS Header / Greddy Evo / S3 cams |
8 hours to kill? LOL .. no thanks
.Nice work nonetheless, looks great! You're almost making my G20 look bad
G20 Toronto & Surronding Ontario |
looking much better, but, that little emblem looks kinda funny IMO
Looks great I am going to send you mine since you have a lot of time to kill ...lol:smoker:
93.5 G20 JDM SPEC SR20 JWT POP CHARGER GROUND CONTROL/KYB ADJUSTABLES 17" VOXX MGR 205/40/17 |
definitely gives the front a more venemous appeal, looks tough as sh!t, and i like the small infiniti embelem, but it would look good either way. sweet job.
Drive it like you stole it :smoker2: Any sufficiently advanced technology is indistinguishable from magic. |
yeha i know thats from teh origanl grill, and i think u should go with out. its too small for the front like that. maybe get one of those big Q45 emblems
Good work......the small emblem isnt bad if you put it in the corner, not the middle! :alien:
:licker: :smoka: :flash:
Yahnozha, is that the custom hood grill from DaKine? How does it mount onto the hood for support? is it sturdy?
1999 G20 |
good job ! looks clean. I don't think i can be patient enough and take the time to customize my own grill, but much props to you. Hey, wouldn't the front grill look tite with a Q45 emblem?? that would stand out nice and BIG !! IMO lates.
And no, Dakine didnt make this one, I did, I just gave him props for the inspiration. Im guessing if I were to do it over again it would take about 3 hours or so maybe less...hummmm......... Anyone have a pic of that Q45 emblem?? Id like to see it.
