Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 03-26-2005, 12:31 AM
marzec309 marzec309 is offline
Send a message via MSN to marzec309
Aurora with Low Voltage
Today my Aurora's Charging system was working just fine. Untill i got back in it later today. After starting it up the volt light on the dash board came on. Shortly after the DIC stated to check the charging system. So i scroled through the DIC and all i was getting for volts was 11.6~11.8. I beleave My alt. jest died does this sound right. After reading through some posts i went and checked the ground at the battery and the motor ground but all were tight. any idea's before i fork out the cash for a new alternator.
thanks Mike. :
Old 03-26-2005, 01:26 PM
treeboy38's Avatar
treeboy38 treeboy38 is offline
You can check the votage in the battery with a voltmeter (ignition off) and compare it to the voltage in the battery with the ignition on thus the alternator charging.
1997 Burgandy Aurora
Old 03-26-2005, 05:28 PM
Re: Low Voltage
ya when i looked at it today in the light and warmth. the battery was 12.04 volts ingnition off and 11.68 volts running. Its the alternator no doubt.
because when i started it today the barrings started to sqeall. thanks for the help treeboy38.
thanks mike
