Old 03-25-2005, 10:45 PM
silveradoking silveradoking is offline
Wiring Through Firewall....
I hope someone can help me out...and in a bit of a hurry...I was looking to install these emergency lights on my truck, and got stuck on where do I run the wires through the firewall....I can't seem to figure it out...the lights are behind the front grill, and the switch I would like it on the kickplate under the steering wheel....How do you run those wires? Can someone explain in detail... Thanks a bunch....
Old 03-26-2005, 02:44 AM
Faze2183 Faze2183 is offline
Send a message via AIM to Faze2183 Send a message via Yahoo to Faze2183
Re: Wiring Through Firewall....
where ive ran my wire for my strobs was i pulled up the carpet on the driver side and theres a rubber garmount there and i ran the wire threw there
02 Chevy EcSb Z71, 5.3, Helix Tb Spacer, Ebay intake, AirAid MIT, F-M-D-F 50 3'' in and dual 2.5'' out, Msd 8.5 wires, NGKTR55 IX plugs, B&M 25k Trans Cooler, Hypertech 160, 4th gear servo, Vette Servo, Transgo ShiftKit, Nelson Tune, Nelson Harness, Ls1 fans,Toyo Open Country A/T 285.75.16 15.9673 @87.29mph in the 1/4
Originally Posted by Nikolai
People with ill-aligned priorities should be sent to California or something.
Originally Posted by Irish_Con
Never doubt boost fool it gave my neon balls
Old 03-26-2005, 07:20 AM
Faze3's Avatar
Faze3 Faze3 is offline
Yup. The other Faze is right. You might have to pull the carpet back some, but there's some grommets there.
I did the same thing when I ran the power for my amp - Pulled the wire through the firewall under the driver's side.
Old 03-26-2005, 10:01 AM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Yep. I rarely have to drill holes in cars these days doing what I have to do. There is usually some HUGE gromet to use. If I am running small wires like for an alarm or remote start, I use a 12" piece of brake tubing. I cut one end at an angle. It works great. You just simply push it through the gromet then feed the wire inside it. Then, go on the other side of the firewall and pull all of it through. That way, you don't have to worry about wires chaffing.
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
Old 03-26-2005, 06:31 PM
Sorry, what does a grommet look like? How far do I have to remove the carpet, or do I have to move it all? Thanks for all the help.
Old 03-26-2005, 07:33 PM
Faze3's Avatar
The grommet's gonna look like a round or oblong black rubber or plastic plug.
IIRC, I ran my wiring up above the steering column, and just used a flathead screwdriver to pry it off enough to push through the wiring. I used a screwdriver long enough that would allow me to have enough leverage to pry open a big enough gap to reach it from both sides.
Hope that helps.
Old 03-26-2005, 09:45 PM
Thanks for all your help...will try tommorrow and let you guys know how it goes....
Old 03-27-2005, 01:25 AM
these days u gotta worry about drillin threw the firewall, on the older trucks nah lol
Old 03-27-2005, 11:34 PM
Thanks for all your help guys, I found the grommet, it was located in the left side and was only about 1 in a half inch by 1 in a half inches...You only needed to remove like less then one foot of carpet...was really easy....Anyways, I added my lights and they are so cool, the blue then the red, then the blue then the red again....looks like a cop car....Now I can stop any dawm Honda, and write him a ticket....I want to get some more strobes....I think I'll give ebay a shot once again....I guess the modding never stops, once you start you can't stop.....REALLY ADDICTIVE.....
Old 04-02-2005, 06:19 PM
ddominey ddominey is offline
strobes
hey how did you wire in your strobes?
Old 04-02-2005, 10:23 PM
oh, man......lot's of extra wire....took me couple hours for sure.....I don't know about your system, but a lot of them are wired differently, what kind of strobes do you have.....What company, and model?
