Old 03-25-2005, 09:32 PM
rubberman rubberman is offline
Synthetic oil....
My GP has 78K miles and have no oil leaks nor does it drink oil. Thinking about switching to synthetic oil. IS it basically too late to switch? any good brands? do i use a regular filter like the PF52?
2000 Grand Prix GT w/ gold package.
K&N CAI intake, U bend delete, ZZP PCM, Ractive oval exhaust tips, ZZP 3" downpipe
2004 Chevy Trailblazer EXT
Keep on Keeping on...
Old 03-26-2005, 06:43 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Synthetic oil....
Change whenever you like. Mobil 1 seems to be the oil of choice but Castrol, Penzoil or any of the others are as good. I use Amsoil in my vehicles but they recommend that the engine be flushed before installing their oil. So if you just want to change without any of the extra hassles the above brands are a good choice.
You may have some leakage around the valve cover gaskets once you change. Pontiac used a lacquer coated gasket on some engines and the synthetic oil tends to cause small leaks in that area.
Old 03-26-2005, 10:15 PM
i also heard the the first 2-3 oil changes still need to be done around 3000 miles since the synthetic cleans out the leftover gunk/buildup in the engine. is that true?
Old 03-27-2005, 02:31 PM
gpdragon gpdragon is offline
Send a message via AIM to gpdragon
Re: Re: Synthetic oil....
mobil 1 is your best bet with a detergent thats what my bubby and i use in our raceing motors and that what i use in my prix after the swap i did. you do need to be carefull with the first oil change because if they don't get all the old oil out it can gunk up bad, but it will clean itself out down the road. but yeah it will be a clean running engine down the road
Old 03-28-2005, 08:51 AM
wylie's Avatar
wylie wylie is offline
I also heard once you go synth you can't go back?
I put synth in my Harley and I could realy notice the improvement.
Wish I could afford it in my GP.
Old 03-28-2005, 11:59 AM
KX2000GTP KX2000GTP is offline
synthetic is definetly worth it. I switched to Mobil 1 on my 00 GTP at 50K and have had no problems with gunking. I did the first two changes at 3K on the dot, but I don't think it's absolutley necessary, maybe just good practice. Right now I'm at 68K and still no problems. I'll also add that the car did have non-synthetic oil when I got it.
hey Wylie, how much are you getting charged to switch to synth? If I remember correctly it was only about $20 more than non-synthetic.
Old 03-28-2005, 12:24 PM
Mobil1's website says you can switch back and forth....
Question:
Switching From Conventional Motor Oil to Mobil 1
There seems to be confusion about how to make the switch from conventional motor to synthetic. I am a do-it-yourselfer. Could you provide instructions?
-- Joe D., Miami, FL
Answer:
The instructions are very easy to follow: Simply change the oil as you would normally. Any “confusion” is just myth. You can switch from conventional motor oil to Mobil 1 synthetic (and back again, if you want), without following any special procedures. The only exception to this is with a higher-mileage engine that has never used synthetic motor oil, or with an engine that has used conventional motor oil and been poorly maintained. In these cases, you should still follow the same basic oil-change procedures (drain the old oil, remove the old oil filter, put in new Mobil 1 and put on a new oil filter), but you should follow a regimen of one or two shortened oil-change intervals. For instance, let’s say that your regular oil change interval is 5,000 miles. If you’re switching to Mobil 1 under the circumstances mentioned above, make your next Mobil 1 oil change in 2,500 miles, your third Mobil 1 oil change 3,500 miles after that, and then follow your normal 5,000 mile oil-change interval. The reasoning behind this staggered interval is that a high-mileage engine, or one that has seen infrequent oil changes, will likely have a considerable build-up of sludge and deposits. Mobil 1 will help clean the engine as you drive, but it will have to work much harder in a very “dirty” engine, and so it is best to change the oil more frequently for those first few thousand miles. After that, you can rest assured that Mobil 1 is continuing to keep your engine running clean and well lubricated for mile after mile.
Old 03-28-2005, 12:50 PM
carnutcass's Avatar
carnutcass carnutcass is offline
In my not-so-humble opinion, the "3000 Mile Oil Change" is one of the greatest scams EVER perpetrated on the American public. It is an absolute waste to change your oil that frequesntly.....unless of course you race weekly or operate your vehicle in a very dusty, hot, or congested/urban environment.
It's just not necessary! I'm truly amazed that with all the oil price increases and national focus on conservation that no one has suggested to American motorists that they are throwing their money away by changing oil that frequently.
The stated interval in our owner's manual is what, every 7000 miles? Given the fact that GM has to warrant the engine, if your engine needed new oil every 3000 miles thay'd say so. GM doesn't want to replace any more engines under warranty than they have to!
Done with my rant......thank you and have a nice day!
Old 03-28-2005, 12:54 PM
wylie's Avatar
I checked it out about a year ago when I was at a Quaker lube shop
and it was almost double,I'm going to check again maybe its come down since then.
Old 03-28-2005, 02:19 PM
at Advanced auto parts, its $5 per quart for Castrol syntec oil. So for $25 you can change your own oil using the synthetic stuff compared to the same price the local business' charge for conventional oil changes.
what weight would i go with? same ol 10w30 or what?
Old 03-28-2005, 02:40 PM
carnutcass's Avatar
10w30.....yes sir!
Old 03-29-2005, 10:15 AM
Are you serious? Ok I'm confused...i figured with synthetic you could run longer between changes, I usually end up around 5000-5500, but with the 'conventional' oil wouldn't it be bad to wait that long?
I know the manual says 3000 - 7500, but isn't that dependent on environmental conditions that the car is driven in daily?
I dont' know if I could trust regular oil to that long...I love my car to much to risk conventional oil burning my engine up. Maybe i'm giving it a little overkill, but I want to keep my car and have it running as smooth as it does now for years to come, so to me it's more of a "good practice" to have the oil changed on a regular basis. Instead of 3k or 7k i split the difference and go for around 5k...but that's just my
Old 03-29-2005, 10:19 AM
Re: Re: Re: Synthetic oil....
At the shop I go to, it's somewhere around 38.95 for regular oil change, and 58.95 for synthetic...I know a few of the guys pretty well and bring them a lot of business so maybe they give me a little discount...I'm not sure, hopefully this will help you out some.
Old 03-29-2005, 10:36 AM
BIG-L's Avatar
BIG-L BIG-L is offline
Re: Re: Re: Re: Synthetic oil....
20 bucks for a 5qt jug of Mobile 1 at walmart,wix oil filter 6 bucks = 26 bucks and a piece of mind knowing that you did it yourself
~Larry~
ClubGP Member 6530
Since 2001
Old 03-29-2005, 10:40 AM
wylie's Avatar
You know its about the same here only in Canadian Peso's
So its accually cheaper here?
I think I might go for I just don't like the part about the posible leaks.
