Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 03-25-2005, 08:45 PM
mach1man mach1man is offline
hp ? 95tbird
what is the rating on a 95 tbird with 4.6 thanks
Old 03-25-2005, 09:26 PM
8ate8 8ate8 is offline
Send a message via ICQ to 8ate8 Send a message via AIM to 8ate8
Re: hp ? 95tbird
205/280
1996 Thunderbird LX 3.8L
1993 Thunderbird SC 3.8L
2000 Cherokee Sport 4.0L
2005 Tacoma X-Runner
Jersey Rice
NJ Thunderbird & Cougar Club
Old 03-26-2005, 01:14 AM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
Re: hp ? 95tbird
i thought it was 265 tq.
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 03-26-2005, 01:50 AM
JR Tigerstar's Avatar
JR Tigerstar JR Tigerstar is offline
Re: Re: hp ? 95tbird
Originally Posted by 8ate8
205/280
Those power ratings are based on new(in 1994/95), stock, flywheel numbers.
I've heard/seen average, daily driven, '95s chassis dyno between 160hp/220tq to 177hp/245tq depending on how well maintained the car was.
Old 03-30-2005, 03:13 AM
intrcptrbird intrcptrbird is offline
Send a message via AIM to intrcptrbird
Re: hp ? 95tbird
I found a hp calculator on a site and it gives an answer based on 1/4 mile time, weight, and gear ratio. On the door it says the GVWR is around 4850. I was wondering if that is the car's weight or the towing capacity? I cant remember the difference in the names.
Old 03-30-2005, 09:11 AM
What is the Gross Vehicle Weight Rating (GVWR)?
Simply put, it's how much weight your vehicle is designed to carry. The GVWR includes the net weight of the vehicle, plus the weight of passengers, fuel, cargo and any accessories added to the vehicle after purchase. The GVWR is a safety standard used to prevent overloading.
You do not have to include the weight of your trailer into your vehicle's GVWR. However, you must consider the weight the load will put on your vehicle's trailer hitch or 5th wheel. The weight exerted on the hitch forms part of the load of the towing vehicle and should be included as part of the towing vehicle's load.
If you go run the 1/4 mile, the track should have scales to weigh your car. Most '94-'97 V-8 MN-12s weight between 3660 and 4006, depending on options, amount of gasoline in tank and whether the driver was in the car.
