Old 03-25-2005, 05:51 PM
pkucan pkucan is offline
high oil pressure
When I start the blazer everything is fine. After the engine warms up I have problems. When i Accelerate the oil pressure peaks. When i back off the gas the oil pressure drops to less than 40 psi. Sometimes while driving, oil pressure fluctuates from high to less than 40 psi. Blazer is a 1996 4.3 liter v6 170,000 miles. Any suggestions?
Thanks
Old 03-26-2005, 04:33 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: high oil pressure
oil peaks?
You do know the oil pressure will vary with engine rpms.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-28-2005, 07:21 PM
JC327's Avatar
JC327 JC327 is offline
Oil pressure is going to flutuate with RPM's after warmup. If it is dropping WAY below 40, make sure you have enough oil, and that your oil filter is not dirty before moving on to bigger things.
Old 03-28-2005, 09:07 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
oil sending units on chevys like to fail, if you clunk, ever, stop, thats when you have an oil issue, but like stated above, oil pressure vaires with rpm's and like i said the sending units like to be faulty on chevys
