Go Back   Automotive Forums Car Chat > Pontiac > Fiero
Old 03-25-2005, 05:45 PM
robbybobbyshobby robbybobbyshobby is offline
88 suspension
I currently have a 87 GT 5sp with 53000 miles I have replaced all bushings with poly and installed antisway bar. Im not very impressed with the way it handles. I want to put a v8 in a 88 and am wondering if they really handle that much better? They are harder to come by than other years. Is it really worth it ? What can I do for my 87 to make it better? Will the rear cradle swap off of an 88 on to my 87? What about the front ? Thanks rrm Any 88 gt 5sp for sale
Old 03-27-2005, 06:32 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: 88 suspension
If you want a good handling Fiero, sell your '87 and buy an '88. It will be much cheaper than reworking your '87 the way you suggest.
Also, IMHO a big heavy v8 will make any Fiero, 88 or otherwise, handle worse than stock.
Old 03-28-2005, 06:43 PM
coop8267's Avatar
coop8267 coop8267 is offline
Re: 88 suspension
you could get a smaller aluminum v8 such as a 4.9 PFI.
the 4.9 weighs approx. 371lbs. fully dressed.
the 2.8 v6 weighs approx. 345-376lbs fully dressed.
3.4 twin dohc v6 weighs 492 lbs fully dressed.
3800 SC series II v6 - 445lbs fully dressed.
4.6 northstar v8 - 468lbs fully dressed.
chevy SB v8 404lbs (aluminum heads & intake)(no accessories).
Transmissons-
Muncie 4 speed- 84.5 lb.
Isuzu 5 speed- 98 lb.
Getrag 5 speed- 101.5 lb.
TH125c 3 speed- 151 lb.
TH440T4 / 4T60 4 speed- 177 lb. }
4T60E 4 speed- 186 lb. } overdrive
4T65E 4 speed- 196 lb. }
4T80E 4 speed- 296 lb. }
Old 03-29-2005, 03:06 PM
Old Lar's Avatar
Old Lar Old Lar is offline
Re: 88 suspension
The 88 Fieros were the best handling stock Fieros. If you are doing a V8 build up, you can take any 85-87 Fiero and build up the suspension so that it will handle as well as an 88 Fiero. The one good thing is that there are lots of available 85-87 suspension components and brake components around. The 88's had a limited build run so fewer used parts are available.
If you are doing a major v8 conversion, money won't be a problem, so you can do all the upgrades to make the best handling car in the world. If you are going to do a cheap v8 conversion, don't.
Old 03-30-2005, 07:39 PM
coop8267's Avatar
Re: 88 suspension
depending on how much money you want to spend on suspension there's some really good stuff at http://www.heldmotorsports.com/fiero.htm
