Go Back   Automotive Forums Car Chat > Volkswagen > Passat > '97+
Old 03-25-2005, 04:12 PM
tmrut5 tmrut5 is offline
Send a message via AIM to tmrut5 Send a message via Yahoo to tmrut5
Passat error code 411
I have a 2000 passat the emission light came on, I took it to checker and borrowed their diagnostic computer. It came up with error 411, secondary air injection. I cleared the code. I see this looks like and issue other have had. Any thoughts on why, and can this be stopped from coming on. Car has 69K on it.
Old 03-25-2005, 09:23 PM
boschmann boschmann is offline
Re: Passat error code 411
The only things you can do yourself is to check the vacuum & pressure hoses at the pump/motor. There should be a 40A fuse for the motor, I believe it's on an adapter above the main fuse relay panel. There is a black & brown wire going to the motor, you can run 12V+ to the black wire & see if the motor runs & pumps air (brown should be ground).
Old 03-26-2005, 10:46 AM
Re: Re: Passat error code 411
Thanks, will try. Are there any websites that you know of that have diagrams etc.. of where things are located??
Old 03-26-2005, 06:30 PM
The only online source is in Russian, but you can navigate it with a little effort.
http://volkswagen.msk.ru/index.php?p=etka2
Old 03-26-2005, 10:16 PM
Спасибо (Russian for Thank You)
Old 03-28-2005, 07:48 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
There should be a vacuum diagram on your hood underside or front engine bay abouve bumper.
