Old 03-25-2005, 03:21 PM
UWCguy UWCguy is offline
clicking 5.7 V8
I have a clicking in my 1994 5.7 V8, its worst when just starting and for a few minutes after that, then it fades out. Also when the engine is warmed up and accelerating it clicks. What is it and what needs to be done? Also its been doing for quite awhile, is it causing any damage to my truck engine?
Old 03-25-2005, 08:17 PM
2000CAYukon 2000CAYukon is offline
Re: clicking 5.7 V8
Check for exhaust leaks. Look for broken exhaust manifold bolts and cracks in the exhaust manifolds.
//2000CAYukon
Old 04-07-2005, 07:52 PM
poncaguy poncaguy is offline
Piston slap. Chevy uses short skirted pistons and they knock when first start up, goes away as it gets warm. My 98 does it. Engine guy who rebuilds my engines told me that, will use longer skirted pistons when I have it overhauled........
Old 04-07-2005, 09:09 PM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: clicking 5.7 V8
lifters might be sticking. try adding some lubricity(available from gm dealer) sometimes it works.
Old 04-08-2005, 12:25 AM
SpitAndDirt's Avatar
SpitAndDirt SpitAndDirt is offline
Re: clicking 5.7 V8
Try substituting a quart of dexron III instead of a quart of oil next oil change. If your a quart low on oil right now you could add a quart of dexron and drive until your next oil change. Tranny fluid has a very high detergent quality, which means it will help to loosen up the gunk stuck in the motor. I would also suggest using SeaFoam 1 day before you change your oil. It will further clean everything out. Make sure you are driving it enough to get the motor up to operating temperature(195 degrees ) for at least 10 minutes. Last, you could try actually taking off your valve covers and adjusting your valves using a procedure outlined in most haynes and chiltons manuals. I don't discredit the piston slap suggestion, but I doubt it. I am leaning more towards a semi stuck lifter or lifters. Good Luck. -Chris
Old 04-08-2005, 07:37 AM
jveik jveik is offline
Re: clicking 5.7 V8
yeah my old 350 does that a lot. gets better with an oil change. someone said it could even be a main bearing
Old 04-08-2005, 09:23 AM
jhaymes2002's Avatar
jhaymes2002 jhaymes2002 is offline
exhaust manifold
chevy exhaust manifold crack a lot on the passengers side under the tin. mine was making noise and i found that. when i went to get one at a salvage yard they were all cracked in the same spot. so i ordered a new one from the internet.
96' trans am A4 LT1
cold air intake, flowmaster, computer programmed.
Old 04-08-2005, 12:01 PM
Re: clicking 5.7 V8
yeah if it only clicks when your putting a load on the engine or the exhaust is cold, i bet it could be just an exhaust to block gasket. a friend of mine had the same problem and he was cheap and just tightened the bolts really well and it stopped lol
Old 04-10-2005, 11:04 AM
kenny-1907's Avatar
kenny-1907 kenny-1907 is offline
Send a message via MSN to kenny-1907
Re: clicking 5.7 V8
I tend to agree with the exhaust manifold gasket leak and not the piston slap. Pre 99 modles were the old style blocks and as he said it is the 5.7 and these engines did not have piston slap. I had an 88 with a 350 in it and the exhaust manifold gasket blew out just as i stepped on it leaving a light and it scared the hell outta me , it sounded like it broke a rocker arm or something. It was making what sounded like a loud clicking noise.
**2007 Avalanche LT. **
6" Pro Comp lift
305/55/20 BFG A/T KO'S
K&N FIPK GENII
Flo Pro V force muffler & 4" slash cut stainless tips
Color matched front and rear Bowties
3" polished stainless bull bar and Nerf bars
Old 04-29-2005, 07:45 AM
speedpainter speedpainter is offline
Re: clicking 5.7 V8
Mine was carbon deposit hitting the piston,seafoam took care it it.Sounds just like failed wrist pin
Old 04-29-2005, 10:29 AM
Riche Riche is offline
Re: clicking 5.7 V8
My 97 did it alot when I got the oil changed on time. (in a hurry went to quickie lube no. no.)
I did my next oil change and the problem went away... I would lean towards the lifters
Old 05-01-2005, 10:49 AM
bracketshark bracketshark is offline
Re: Re: clicking 5.7 V8
I don't think GM used a manifold to head gasket (I've not seen one), but one could have been added after purchase, some do leak until warmed up as stated earlier. I've seen numorous cracked SB manifolds also. If you remove it to install gaskets you might have to purchase a tool to spread the manifold to get the bolts restarted they are a PITA on the truck. There was also a GM notice that most of the rattle at start up was the rods slapping together and not bearing noise. I think I remember GM saying that 15 seconds of slap was acceptable. Oil pressure is supposed to separate the 2 rods eliminating that noise.
