Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 03-25-2005, 03:22 PM
rtm1165 rtm1165 is offline
coolant temp sensor??
i recently had auto zone run the scan on my 1995 bonnie it came back diag. trouble codes: history code p0118 coolant temp sensor sensor signal high. where is the sensor located and is it a serious problem??? soes it have to be changed now or what???help please.
Old 03-26-2005, 10:52 AM
BIG-L's Avatar
BIG-L BIG-L is offline
Re: coolant temp sensor??
It could be one of 2 thing's,either a bad thermostat or the sensor.The sensor should be located right below the T-stat housing on a 3.8.
~Larry~
ClubGP Member 6530
Since 2001
Old 03-28-2005, 08:44 AM
thanks man does that sensor have some wires running out of it? you said it could ba a bad thermostat but the car has never run hot.
Old 03-28-2005, 11:38 AM
BIG-L's Avatar
Should be a female plug that goes to the coolant sensor.A bad thermostat doesnt always mean that it is going to get hot.When they stick open the car will run colder.
~Larry~
Old 03-29-2005, 01:17 PM
when changing the sensor is it just a matter of screwing it out and screwing the new one in??? will it be better to replace the theromstat and the sensor??
Old 03-29-2005, 05:18 PM
BIG-L's Avatar
Yes,but you have to get the coolant level below that point of the sensor or you will have a big mess.
Since you have to get the coolant level lowered to remove the sensor,you may as well replace the thermostat at the same time.Buy a Stant superstat about the best one's out there.
~Larry~
Old 03-29-2005, 07:53 PM
thanks for the heads up about the coolent level i may try to change it tommorrow.
