Go Back   Automotive Forums Car Chat > Ford > Probe
Old 03-25-2005, 01:14 PM
joshs93gt joshs93gt is offline
Send a message via AIM to joshs93gt
93 probe gt idle problem
when i'm driving the engine will start to bauge and if i hit the gas the rpm's go down so i usually pull of the road and put in it nuetral and then the engine rev. out. i've heard a few things like the intake manifold gaskets and plugs and stuff like that. if anybody can help me fix this problem i would greatly appreciate it. thanks
Old 03-28-2005, 10:35 AM
925drgn 925drgn is offline
Send a message via AIM to 925drgn
Re: 93 probe gt idle problem
i am having almost the same problem with my 93 probe right now when it is driving it is fine but when i sit at a redlight it wants to stall and when i did a little research i found that the probes of that year had vacum leaks. that might be part or all of your problem.
Old 03-29-2005, 09:28 PM
shawnwilliams's Avatar
shawnwilliams shawnwilliams is offline
Ya the vacuum lines are said to go, the best way is to check is just do a visual check of all the hoses going to the engine, in case theres a rip or a tear in any of the lines. Might just need a new pvc valve.
Old 03-30-2005, 08:27 PM
it shouldn't be the belts i just had them replaced. but then again, the people that replaced them, didn't tighten my lugs all the way when they did my brakes and i twisted 3 of them off by hand. Anyone in Wilmington Illinios, don't go to Northwest Auto.
Old 04-04-2005, 01:17 PM
well i took it in and it is just a etc senser and a fan sensor. better than what i figured it would be.
Old 04-09-2005, 10:55 PM
carissa_099 carissa_099 is offline
Send a message via AIM to carissa_099 Send a message via Yahoo to carissa_099
it could possibly be the idle control sensor. it costs around $100. but vaccuum leak sounds more likely!
Old 04-12-2005, 12:38 PM
jworm420 jworm420 is offline
Ok ive had alot of cars and fixed evry one of them (i refuse to pay people to fix my car) and im pretty good at it, but i cant say that ive herd of an "etc sensor". What is it ?
Old 04-12-2005, 12:39 PM
i ran etc sensor through google and all i can find that it relates to is a dimmer sensor for rack mount stereo equipment.... didnt see anything about automotie use.
Old 04-12-2005, 01:46 PM
i don't know about that sensor, that's just what the guy told me. but i found out that what was happening was that the sensor was tellin the computer that it was -30 degrees outside and it was making me run real rich, thus heat fowling my plugs and sending my rpms to 3000, then it would tell it that it was really hot out and it would choke and the cooling fan would come on. that's all i know this far but i got my car back and it runs like a champ.
Old 04-20-2005, 07:32 PM
bargersaudio bargersaudio is offline
Re: Re: 93 probe gt idle problem
Some models have a engine coolant tempature sensor it runs into the pcm. these models also have a tempature gauge sending unit and a fan control sensor all in the same general area. I would say the mechanic meant the ect sensor not the etc sensor.
