Old 03-25-2005, 11:22 AM
biglogonafrogbig biglogonafrogbig is offline
25% better mpg 30% better horse
Click on the link it claims a 30 day money back guarantee just give opinions it sure sounds good
http://aquatune.com/index.asp
Also this one claims up 35% gain in mpg with just cheap store bought acetone 3 ozs per 10 gallons
http://www.timebomb2000.com/vb/showthread.php?t=143848
Old 03-25-2005, 11:33 AM
Also try looking at these
http://www.lecryo.com/purepower.html
Old 03-25-2005, 11:41 AM
Read this one i can't believe this one i doubt this is true
http://quantumgravitics.tripod.com/
Old 03-25-2005, 12:11 PM
profox02's Avatar
profox02 profox02 is offline
Send a message via Yahoo to profox02
Re: 25% better mpg 30% better horse
does the acetone up ur octane as well..cause i got a 350 with high compression and i have to get high octane gas...will adding acetone up ur octane???
Old 03-25-2005, 12:45 PM
I really don't know alot about it but i think it will up your octane i think 100 acetones octane is 150 so yes it might but just a little bit
I meant 100% acetone
Old 03-25-2005, 01:17 PM
profox02's Avatar
Dosnt Higher Octane Gas Just Give U A Better And More Complete Burn???..so Wouldn't Acetone Basicly To The Same Thing..???
Old 03-25-2005, 01:39 PM
Re: Re: 25% better mpg 30% better horse
I don't really know much about the article but i think that it just makes it burn more gas and waste less
Old 03-25-2005, 02:14 PM
98SilvyKid's Avatar
98SilvyKid 98SilvyKid is offline
Send a message via AIM to 98SilvyKid
Since combustion engines compress the fuel and air mixture, the high compression can actually detonate the fuel. Think about it like this: during the compression stroke, the fuel is under a lot of pressure being squeezed together, and this may blow the fuel up before the spark plug lights it instead. Higher octane levels decrease the chance of this happening. You really only need a high octane fuel if you have a high compression engine.
1998 Chevy K1500 Standard Cab, Flareside Cargo Box,
All Options, 5.0L V8, 4L60E -K&N Filter, Custom Exhaust, American Racing Rims, Manik Brushguard, CF Light Shades, Glasscapes picture, More to Come!
Old 03-25-2005, 02:55 PM
profox02's Avatar
A'ight....i Just Put This Motor In Over The Weekend And Ive Been Running Premium Gas In It...just Wondering If Acetone Would Do Something..if I Just Added That And Got 87 Octane Instead Of High Octane Gas That Is Expensive...so I Guess I'll Stick To Premium For Now..
Old 03-25-2005, 09:09 PM
J-Ri's Avatar
J-Ri J-Ri is offline
It only ups the octane a few points, if mixed to increase gas mileage. If you mixed it for higher octane, you would get worse gas mileage that with gasoline fo the same octane rating.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 03-26-2005, 12:55 AM
Silverado Brethern's Avatar
Silverado Brethern Silverado Brethern is offline
Yeh i think im gonna definatly try this. But ill hafta get a full tank first to test mpg. note a full tank, not a tank from F cuz the F on the guage isnt full. so i will test from completely full to 1/2 cuz that really the only acurate way to do it. Do that a few times then go find some acetone (pronounced acit-tone). And after a few 1/2 tank runs with that ill report my findings. All i have to say about the deterization of plastic parts is that it would be non-existant. ie: yes acetone corrodes plastics, also yes clorox is harmful to drink, however if you drink 3oz. of clorox in 10 gallons of water you will never even know at all! The amount of acetone suggested is so small im curious as to how it could even effect mpg. but who knows....its worth a try.
"Never under estimate the power of stupid people in large groups."
1997 K-1500 Silverado Vortec 350...125,610 and wounded
HD chassis package
Custom TRUE DUAL exhaust with cut-outs and Flowmaster 40 series mufflers
Poweraid Throttle Body Spacer
Custom Ram-air Intake with K&N FIPK GEN II
TFES Performance 3" Suspension Lift
Dual Air-Horn Kit with Compressor
Bed-Mounted 48" Hi-Lift Jack
Cobra Laser Radar Detector
285/75/R16 Cooper Discoverer STT's
1/4 Mile 10/15/05: 16.43 @ 91mph
Old 03-26-2005, 03:46 PM
Chevy-SS's Avatar
Chevy-SS Chevy-SS is offline
Has ANYONE tried any of those gimmicks? I can almost buy into the water-injection system. I have seen that many times before. I can't believe it would still be around if it was a complete rip-off.
Old 03-29-2005, 03:23 PM
sub006 sub006 is offline
In my experience higher octane gas burns faster. You get more power and less mileage. My old 64 Corvette with 327/Powerglide would spin its rear tires on Chevron Custom Supreme (103 octane) and would not on Super Shell (100 octane). I was going to switch to Chevron til I saw how faxt the tank emptied (and no, I wasn't driving it harder).
Lots of changes can affect seat of the pants performance. My son installed a K&N FIPK intake and Gibson cat-back exhaust on his 04 Silverado. It now peels out from a standing start, which it would not do before.
Old 03-29-2005, 04:42 PM
Yeh guys i dont this is workin well at all for me. last fill up of regular gas with open cut outs got me 150 miles from complete full to 1/2 tank, which is about 12mpg (better than i have gotten in a long time anyway). But after that i filled up again with regular and as of now its past the 3/4 mark and right at 70 miles. Not done with the test yet but im pretty sure its making my gas mileage work. As far as power i have no real way to judge that but there is nothin spectacular or even noticeable. I have been told by a mechanic that no matter what the onctane rating of fuel is it will effect a vortec engine little if any. Just the same deal as vortec engines run the same on regular 87 as they do on premium 93. I will post my exact findings when done then do a test with the cut outs closed. Also if ever the diesel shop in town gets its dyno building done i will test the performance on that. I get to run for free any time i want cuz Im doing the plumbing for them.
HD chassis package
